Engine cuts out?
residentg
...why did I do that?
one more thing - check the air filter - is it clogged or oil drenched? If so, try running the engine with it removed to see if it makes a difference, if so, replace it.
crappyballer
T-Tecumseh?
the filter is only a week old w/ like maybe an hour of use on it. I was able to squeek a small test run in yesterday and the spring seemed to do the trick. thanks for all the help guys
sixburgh
Pittsburgh, Pa
My engine cuts out too!
:confused:Modified tecumseh 6.0 hp, cam, hedder, valve springs, venturi in carb honed out a little, govenor removed, etc.....It has tons of power but cuts out over bumps and stalls after releasing the gas pedal after a full speed run. It feels like it is being starved of fuel. Anyone???
crappyballer
T-Tecumseh?
well after long test run yesterday my kart has improved 10x but it still cuts out here and there so i am still messing w/ my gov spring. as for your situation six have you tried returning your carb to stock? maybe the honing messed something up? have you tried cleaning your in tank fuel screen?
Kaptain Krunch
Pro Junk Collector
vermont
try a slightly larger main jet.
Kaptain Krunch
Pro Junk Collector
vermont
