Diamonite Electrathon America Racer
Hey T,
Yup, them pics are pretty much self explanatory
...& the "thingy" looks like the "thingy" in the drawin' :2guns:
Yup, probably be best ta just send ya a wheel :thumbsup:
Also, while your playin' with that sprag/freewheel unit (if ya could) take a look at the bearings
1.) it seemed like there ain't enough of 'em in there (please explain)
2.) seemed kinda "dry" in there (also...please explain)
...just wanted your observation/opinion/commentary :cheers2:
We've had some ~60* days :bannana:
...still too cold ta do fiberglass work :furious2:
But,
I can do some other stuff :wai:
Lookie what I made
Liked it so much that I went a made a bunch of 'em
Then, Jaulla asks "how'd ya get them "corners "knocked off" evenly
...& all of the holes "straight" (or to line up) so "nicely"?
Good question Jualla ;)
Well, first I measured, marked & drilled "marker holes" (shallow "indents" to help center the drill bit when using the drill press)
...& also, measured, marked & cut the corners off of (1) of 'em
Then, just "stacked" 'em up
...to cut the rest of the corners "to match"
...& also, drill the holes, all together (or at once)
So, they all will match "pretty closely" :sifone:
There’s that dog gone Julia again.
Hey Denny,
Well, I guess Jualla is my "imaginary" Electrathon America vehicle build/class "student"
She (yup, she is a she) asks questions
...so, I can elaborate on stuff...without...seemin' like...I'ma talkin' to myself :innocent: (* yea, I've been warned about that) :devil2:
So, why are some shorter than others
...& what ya gonna do with 'em...she asks :cornut:
Well...(4) are for the tops (longer ones)
...& (4) are for the bottoms (shorter ones)
First, I'ma gonna put 'em in the bender
...do some bendin'
Left one was a "test" (turned out OK)
...so, I went ahead & bent the other (3)
Next "test" was to try-n-bend (1) around a ~3/4" dia. piece of pipe
Here is a bent view
Then, clamped 'er to the edge of the workbench
...& tried ta bend 'er around the piece of pipe some more
The "top pieces" (longer pieces) turned out lookin' like this :thumbsup:
...& this
Then, I went ahead & bent the lower pieces (shorter ones)
...@ about a 90* angle
Then, just "stacked" a "top piece" on top of a "bottom piece"
...like this ;)
Another view
Yup, I made up (5) of 'em
...just in case I totally messed (1) of 'em up while fabricatin'
...or if (1) of 'em just turned out kinda "wonky"
...or even as a "spare" custom part :cheers2:
Now if we only knew what they were for. :ROFLMAO:
Hey Denny,
Ya can't tell? :huh:
They are an "idea" for some lightweight A-frame Bushing holder/mounting brackets :thumbsup:
This is kinda what I have in mind
But, notice how the brackets would only be mounted to the side of the monocoque
So, my thinkin' was that it would be better (stronger) ta have 'em mounted on (2) "planes" or different surfaces :cheers2:
Here is some info...for reference ;)
This is a (bottom view) pic of the front suspension on my mini-Areial Atom kart
The A-frames are made outta some 1" square tube
...& some 1/2" Schedule 40 water pipe
The A-frame mounting brackets are automotive (7/8") Sway Bar Bushings
It's kind of a heavy kart
...so, yup, they work very well
...but, for a "lightweight racer" they seemed ta be WAY too HD or "beefy"
So, I've been thinkin' & lookin' at some different materials
A few different sizes of steel tube, with different wall thicknesses, pipes & even some solid rods
Yup, I even contemplated possibly just using some electrical conduit tube
...with a couple of "C" style mounting brackets
...& a "stock" type spindle mounting bracket
...but, it would look stupid :ack2:
...& the "metal" conduit is made of is just WAY too soft
* Quick demo: clamped a set of vise grips on
...pushed down
...& it just/easily tore out"
Another "for reference" pic
This is the front suspension is on my Sequoia racer
The A-frame is made of 7/8" OD x 1/8" wall steel pipe
...1/8" thick steel mounting brackets
...& 1/8" thick steel shock bracket
...& 3/16" thick steel spindle bracket
It's good-n-strong
...but, good-n-heavy too
* Notice, the 1" x 14g steel tube, bushing holders
...& 1/8" thick steel mounting brackets
Well...for this "racer" the "goal" is to create a really light weight chassis
...& using HD materials didn't align with that goal
...but, they still gotta be strong (in design & materials)
So, my thinkin' went to...I've used 5/16" solid steel rod for tie-rods for "controlling" the direction of the wheels
...many, many times
...& with some pretty good success
But, 5/16" rod seemed "undersized" for this job (A-frames are usually made of ~1" steel tube)
So, I looked at potentially using some (thicker & stronger) 3/8" rod
...with some threaded-on steel, swivel rod ends
...& some simple "C" mounting brackets
But, look at ALL of the parts that would be required
...(2) 3/8" rods
...(4) rod ends
...(2) mounting brackets
...plus, some nuts & bolts
Then I thought, "if" I just use (1) longer rod (bent in the middle)
...it would eliminate the cost & weight of (2) rod ends
Then, I thought that "if" I also, bent the (2) ends I could eliminate
...(2) more rod ends
...& also, the nuts & bolts required for mounting
The 3/8" rod would be bent at the line
...with a small "washer" on each side
...& maybe have each side "secured" in place
...with a small cotter pin (not shown) on the outer sides
Atlanta, GA
Thin solid rod might introduce this vehicle to the melodious sounds of harmonic vibration. You could always sing along as you go.
Nice work FA. Making one is easy, making repeats is hard.
Hey WTR,
Anymore when I'm designing a part, the actual "Fabricat-ability" of "multiple parts" is one of the main factors I always...try-n-keep in mind
Creating & maintaining consistent fabricating "habits" (using the same concepts & practices) helps to do things over & over
...plus, taking lots of notes (about what you're doing & why) helps
...& taking lots of pics "along the way" helps too :thumbsup:
But/still, sometimes ya "go to" make a second part
...& somehow kinda...get distracted...&/or forget...important details like
..."did I bend it...on the line...just before the line...or just a bit past the line?"
...& it comes out like...WTF :ack2:
* After I made the first A-frame
...I got a couple of "tow calls"
Then, a couple of hours later, when I got back
...I kinda was like
..."where the "F" was I at?" :huh:
So, when I tried to make another/matching A-frame, I somehow ended up making (3) DUDS (technical term for bad parts) :mad2:
I used the "ways" that I thought I used, ta make the first one
...but...NOPE...the mounting ends were too short (top right)
...on my second try...NOPE...didn't even get to the "ends" because I made the middle bend, way too wide (mid right)
...& then, even tried a third time...NOPE...Um...way too narrow (bottom right) :furious2:
OK I figured...that's enough for today
...&/so, we'll get back at it tomorrow :2guns:
Um...my truck kinda "freaked out" on me :ack2:
...&/so, have been kinda pre-occupied
But now, I'ma justa waitin' on parts... :popcorn:
So, I figured that this may be a good time, for a different distraction :thumbsup:
So, to make another
...or a couple more A-frames, I went back at the "beginning" or "back to the basics"
I cut (2) more (24") pieces of 3/8" rod
...& then, marked 'em (both the same)
Next, I put 'em in the bender (one at a time)
...lined it up "right on the line"
...& worked on the (2) center bends (bending 'em...all about the same) :wai:
* Notice, for the "end bends" I used a "stop block"
...so, all of the bends would be "in the same place"
...& all of the 'ends" would be the same length
Then, using a "straight surface" I made sure the "ends" were both "level" & "even"
Um...nope...not yet
After a bit more bendin
Yup, that looks better ;)
Now, the original A-frame has some "pretty closely" matching "friends" :sifone:
Another view :2guns:
First thought, for a spindle mounting bracket was an "all-n-one" unit
...with a spindle mount
...the base or brace
...& a shock mounting bracket, all "built into" one bracket ;)
Kinda like this "mock up"
But, thinkin' it thru
...&/also, thru mockin' it up
...I noticed that the Castor Angle wouldn't be adjustable, "if" I did it as an "all-n-one" piece :huh:
So, on to Plan B
Next, I drew out the "all-n-one" idea
...but, left the "upper & lower" spindle bracket "tabs" off :cornut:
Then, cut 'er out
...& just in case, I messed this one up, I "traced out" another one
Maybe something about like this :2guns:
Jua'lla says that piece "looks" kinda neat
...but, how strong is it gonna be? :unsure:
Well...we are goin' for light & strong
...so, maybe a bit of "boxing it in" would help :thumbsup:
Kinda like this
Another view
Yup, CAD (cardboard aided design) at "its finest"
...it's just a piece of cereal box cardboard & some scotch tape ;)
Mocked up with the A-frame
Another view
Close up
This is about how it would look with
...the spindle bracket
...& a coil-over shock :sifone:
