Diamonite Electrathon America Racer
Wholy crap! :eek:
Are the bearings seated correctly?
Do both black rims behave the same?
The "play" in the freewheel unit doesn't seem to be that bad...from here
Hey T,
Looks like ya "warped" it pretty goodly :lolgoku:
I went & checked on the black rim, that I have
...& somehow, ya must have "warped" this one too :huh:
...because it's "all over the place"...as well :furious2:
JK...JK :innocent:
Maybe...seems like...(2) piece plastic rims aren't such a good idea...in this...specific situation :mad2:
Hey T,
JK...JK :innocent:
Lemme see if there is something misplaced,displaced, or replaced. I just grabbed 2 halves maybe one is screwed up? Maybe a different combination will be mo bedder?
they should be all identical, tho.
The "other" hub:
Is there anything else sharing space on that hub?
lf not, l can remove the studs, turn thr OD down.(flange) then drill and tap it to fit the rotor.
then everybody can live happily everafter!
With some gental persuasion, the wheels can be brought into tolerance, or at least acceptable.
https://youtube.com/shorts/XuCv5PthAPk?feature=share
https://youtube.com/shorts/DL1S7Sfxask?feature=share
persuader:
You have to screw around with different combinations and adjustments to get runout within reason.
The rotors are so thin just torkin the screws will adjust them.
Runout is in both the axial and radial direction.
Hey T,
Yup, that looks a bit better :thumbsup:
The "other" hub:
Nope, just a rotor
...& sure, modifying the hub to "work with" the rotor
...sounds like an adequate solution to me :cheers2:
I have a couple of ideas, please view exhibit "A"
exhibit "A" shows the hub sitting on top of the rotor.
Plan 1A is to cut the hub along the plack lines, indicated by the red arrows.
then chuck it up inthe lathe to make it round.
that leaves little room for bolts.
So my suggertion is unconventional, maybe even stupid and l'm gonna hear alot of *****in and WTF's. It will work, it is easy and quick.
Weld it!
yeah, yeaah, l know. Seriously, do you ever expect to wear out, or damage a rotor?
l've done this wheh there are no other good options, without adverse consequences.
plan 1B
Turn it down, then drill and tap it for #10 screws.
lotta work.
Finished the odd hub.
I turned a step to locate center, as the rotot ID was mo bigger then the hud. Radial runout is nil, but there is some axial runout but nuttin serious.
The welds look like carp due to paint and other stuff off gassing. They are solid welds however.
They have the usual guarantee, 100,000 miles or 10 minutes, whichever comed first.
