Converting to live axle
dave1701
Good for 100,000 Miles
MICHIGAN
My only concern is that my wheels my have too much traction (I have big snow hog tires on them now) and wont let me turn well
imSRB
inwood, WV
dave1701 take a closer look at my setup It's all bolted together and thats what I did converted to live axle
dave1701
MICHIGAN
I'm gonna need new wheels, because the ones I have now are desighned to run on spindles, and have no place for a hub. They are 6".
Could someone show me what wheel I would need?
dave1701
MICHIGAN
Take a look at the picture and let me know if you think the bearings would be close enough to the ends.
PS: Is my band brake gonna be weaker with the live axle?
I don't think you want to put the bearings there. I see a taco'd axle in your near future. Best to alter the frame first. Plus, you don't want the sprocket outboard of the bearing. The chain will induce more stress on the axle, and you're likely to have chain tensioning issues as the axle flexes
gokart14
Nebraska
I have this exact go kart and my futer project is to change it into a live axle like your doing looks like this will work
theo
It's not a good idea to drill through a tube to bolt on a pillow block bearing, it will eventually brake the tube and one of the holes, unless you weld in a through tube. I would either weld on a azusa bearing hanger or weld on a 3/16" plate to bolt a pillow bearing.
I would get rid of he band brakes and install a hydrolic setup especially on a 2 seat.
dave1701
MICHIGAN
You have the same kart as me? cool. I'm gonna start this project after schools done (a week and a half). Do you have a same 1 wheel peel problem?
gokart14
Nebraska
ya it is so anoying!!!!:( it just will spin if you try to go,after you stop The one good side is you can burn out really easy!! I would try to change it know but i am in the process of building another go kart. But good luck
dave1701
MICHIGAN
I'm gonna start on this project soon anyone know where I can get the parts cheapest?
