Converting to live axle
dave1701
Good for 100,000 Miles
MICHIGAN
I'm thinking seriously about switching my go kart from a one wheel drive to live axle. The one wheel drive keeps pissing me off. It's gonna be a major project if I do it though. The wheels are just on little spidndles that are welded on there so I'd have to cut those off. I guess I could put the axle in that tubing. I don't know a whole lot at all about what to do, heck I don't even know if it's possible. Can someone tell me what I would need to do to convert this kart. Do I need to weld? I can't.
dave1701
MICHIGAN
Question #1: Can I put a hub on the wheel I have now, or do I have to get a new one?
Question #2: I don't have to re-position my motor do I?
Question #3: I don't think I understand some of the basics, what keeps the axle from sliding around back and forth?
Question #4: What are the ends of the axle threaded for? Can someone give me a go-kart axles for dummys link?
Question #5: I have real knarly snow hog tires on my rear wheels. With that cause me to not be able to turn worth a darn?
Question #6: Do I need an extra strong hardened steel axles or wil a normal one be fine?
Question #7: The part that I would put the axle in is an important part of the frame. Is that a problem?
Rotore
Teh SPIK
Caguas, Puerto Rico
Q1: yes just find a hub with the same bolt pattern as your wheel
Q2: not if you put the axle under the frame but rear will be a 1/2-1" higher
Q3: lock collars, most if not all bearings have a screw that holds the axle
Q4: for a nut that keeps the hub on the axle
Q5: steering will be a tad bit harder unless you buy the axle with a differential but you'll have more traction either way
dave1701
MICHIGAN
Thanks alot Rotore. The thing I don't understand is this: Where am I accually gonna put this axle? Am I gonna somehow attach it to the bottom of my kart? Could I put the axle right through that tubing that is my frame, or would I have to rig up something to attach it to the bottom of my kart.
Rotore
Teh SPIK
Caguas, Puerto Rico
i think that tubing is to narrow for pillow blocks so im going to suggest this bearing kit from bmikarts.com. all you have to do is weld those 2 plates onto the kart and the rest is just bolting it on.
