Building a go kart size Aerial Atom
Tpdingo
Bellmore, NY
Lets bend some pipe :thumbsup:
I think we can incorporate the seatback/rollbar in with the bottom of the motor box.
(see drawing below) :cheers2:
Started with a 10" piece of pipe.
Marked at 20", 60" & then, at 100"
Bent it at the 20" mark to ~75* angle & also at the 100" mark to ~75*
(being sure to keep 'em in alignment)
Then, turned 'er ~90* & bent 'er to the max right in the middle at the 60* mark.
A ratchet strap easily draws 'em together to ~12" apart. :2guns:
I used my flexy straws and now my own Ariel Atom is done. I made sure to use my Harbor Freight hydraulic flexy straw bender.
It runs off coin cells and can haul two fat ants around.
:roflol:
I don't have any flexy straws :(
Nice work though! In its current state...it makes a nice coat hook! I'm sure the people at Ariel must love having their car being used as a coat hook :lolgoku:
Rear Suspension
Well, that's a beginning, but what's next? :idea2:
I guess we'll start @ the back & work our way forward. :thumbsup:
An actual Ariel Atom has an independent rear suspension with a transaxle & individual axles going to each wheel.
Were not doin that. (at least not on this one) too complicated & expensive :ack2:
I think a swing arm that travels in between the bottom motor box rails might work pretty good in this situation..
So, next is to make a swing arm.
On this one, I'll just mount the motor & axle to the swing arm & then mount the batteries elsewhere.
First, we need to make a motor mount plate. (3/16" x 4" x 6" steel)
Measured, marked & drilled (8) 3/8" holes, (2) for each slot.
I used a Dremel to cut out the remainder of material & then, filed 'em 'till the bolts slid easily, in the slots.
* I am using 3/8" round headed bolts so, I don't need to use a wrench from the bottom side, when mounting the motor. :2guns:
Swing Arm
For the swing arm I'll use 1" square tube, because it's easier to "square up" & the flat sides help the "rub rails" slide smoothly. :thumbsup:
First, I lined the (2) main rails up & drilled the "hinge holes".
Next, I squared a main rail up with a cross rail & tacked 'em together.
Then, squared & tacked the other (3) corners, double checked everything & welded 'er up good.
* I left ~2" in front for the "hinge" bolts & made the rear nice-n-flush. :2guns:
Before mounting the motor plate we need to mount the axle, sprocket & bearings so, we can line everything up.
I sat the motor in place, too (didn't get any pics) & made sure everything was in alignment & cleared nicely.
Then, welded the mount plate on good. :2guns:
* Notice the way the motor mount plate got bowed a bit from welding.
Now that we have a swing arm we can get back to the rear of the frame.
Went to set it in between the frame rails, but they seemed kinda tweaked. :ack2:
I know the swing arm is square so...
Checked with a "big" square & yup, the one on the right os off just a bit, but the one on the left is off quite a bit.
Guess we are gonna have ta do some "body work" :thumbsup:
Clamped 'er down on the back of my truck (a 10,000 lb. winch will do the trick) using a couple of 2 x 4's to spread out the pressure.
Then, slid a piece of scrap 1 1/2" pipe (for leverage) over each side & tweaked 'em back to being square.
(90* with the seatback)
Next, I added a couple of "outer" rub rails. (in side of the motor box)
This way the swing arm doesn't bump, catch or clash with the lower motor box tubes
Also added a couple of wear pads (in between the hinge rails) to avoid metal to metal scraping. :thumbsup:
Will probably add a couple further back. (for power sliding) :2guns:
Once we knew what the dimensions needed to be I made up a couple of "cross bars" & welded 'em in to "lock 'er together" :cheers2:
Motor Box
Now that the bottom of the motor box, with swing arm, is done lets "build 'er up" (work on the sides & top) :thumbsup:
First, had to do some "mock up" work to get the measurements.
According to the pics, the bottom of the motor box should be just below the axle & the top should be just above the top of the rim, but not the tire.
The bottom of the motor box was supposed to be ~12" wide (between the wheels)
...but, ended up a little wider. (~14")
So, where the top should have been ~16" previously, (we had to adjust it accordingly)
…it now needs to be ~18" wide
Then, another quick "mock up" using those figures & factoring in the angles, it looks like we would need to make the upright "pillars" ~5 3/8".
This should put the top of the motor box just about where we need it to be. :cheers2:
I finally get to use a bunch of scrap pipe that I've has in a bucket for years. :wai:
2 - 18" pieces for upper cross bars
2 - 12" pieces for the rear ends of the lower "rib rails"
4 - 5 3/8" pieces for the upright pillars.
Cleaned 'em up, squared 'em up & welded 'em up. :2guns:
Now we need the pillars to hold 'er up. :thumbsup:
Used the "rough" grinder to "notch" the ends of the (4) "pillars" (5 3/8" pieces of pipe)
I sat the rear frame section (lower motor box) on the bench, sat the upper motor box on a coffee can & used a couple of boards til' the pillars would just fit in. :cheers2:
Then, used a square & tape measure to get 'er centered & squared :2guns:
I used the magnetic square to help keep the pillars ~90* (from front to back) & ~45* (from side to side)
Tack welded 'er all the way around (top & bottom of all (4) pillars)
Double checked everything (distances, angles & "the look")
Then, welded 'er on good. :thumbsup:
Looks like somethin' is startin' to take shape :2guns:
It is starting to take shape quite nicely. Thanks for all the pics. Even though I don't comment too often, I find myself living vicariously through your builds :D :thumbsup:
Thank you very much. :thumbsup:
I kinda try to do my "build threads" like they did in the old Hot Rod magazines. :cool:
Step by step with lots of pics & details. :2guns:
…& hopefully we have something kool in the end :cheers2:
* If ya think about it, Go karts are mini Hot Rods :auto:
I think I did it! :thumbsup:
I made some "bows" :bannana:
Instead of making (2) separate "lower rib rails", I figured I'd try to make (1) big "U" for the "nose"
...& then see If I could add the "bows" to it :thumbsup:
First, I measured & marked another 10' piece of pipe in the middle (@60")
...& then 6" each way (@ 54" & 66") for the "nose" bends
I also measured & marked it @ 6", 12", 16", 20", 24" & 30" (from each end) for the "bows"
It took ~40 pumps @ the 54" & the 66" marks to establish the "nose"
To help "widen" the bend, I adjusted the rollers "out" a couple of notches
(It's adjustable for bending larger diameter pipes)
Then, I did 5 pumps @ the 12", 16", 20", 24" & 30" marks (on each side)
...which "bowed it in" to meet up with the upper motor box rails pretty nicely. :2guns:
Our lower rib rail looks pretty good :thumbsup:
...but (sorry to say) it's a little bit too wide. :ack2:
So, I measured 1" each way from the center mark & cut a 2" piece out of the middle. :cheers2:
I'll use a 3" piece of 5/8" rod to "pin" 'em back together & then, weld 'er up good. :2guns:
The "nose" was ~14" wide, now it's ~12", much better. :cornut:
Lets see if we can "get 'er together" :thumbsup:
Marked, trimmed & cleaned the ends up a bit.
:cheers2: How's that for "triangulation"? :smiley_omg:
Propped 'er up on the "right" angle & clamped 'er down
Tacked 'er on (both sides) double checked everything (height, width, length & the angle)
...& welded the lower rib rail to the motor box. :2guns:
Not perfect :worried2:
...but, looks pretty good! :thumbsup:
Lets catch up a little paperwork :cheers2:
I made some adjustments to the measurements, again (for like the 56th time) :thumbsup:
Now, it looks like we'll have ~48" wheelbase & ~60" overall. :smiley_omg:
So far, we have made
1.) seatback/lower motor box combination
2.) the rest of the motor box
3.) & the lower rib rail
