bluethunder's projects
Bluethunder3320
@daftmachine thanks, man!
@redsox985 yeah, the cart was just an idea
i should be totally done with the bike this weekend.
@That One Guy ...thanks? lol ;p
@r97 i would like that very much, lol, but the thing is i dont even know the dia or pitch. and yeah its a nut. i went to 4 diferent hardware stores and they no haz my hardware.
this is the manual if it helps....
http://www.razor.com/$assets$/26c3c2bb-d15e-4531-9157-70ec1128fb5b/MX500_MX650_Manual_V1_01-10_US.pdf
ive already done a ton of online searches couldnt find it.
r97
Measure twice cut once
Massachusetts, USA
ok i'm not having luck with getting a stock razor part, first off identify if its metric, or sae, this is done easly by measuring the diamiter, preferibly done with a caliper (if you don't own one buy one(super handy), try to get one that measures sae, and metric). next if iits metric, measure the threadnpitch (distance between tops of threads) be exact as possible, this measurement will prob just be a rough guesse, so try nuts near your "guess". if its sae, measure out 1" of thread and count the # of threads, tell me what these measurments are, an easier way is to buy one of these to get the measurements, http://www.homedepot.com/Tools-Hardware-Hand-Tools-Measuring-Tools-Gauges/h_d1/N-5yc1vZ1xpxZarzn/R-100186831/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
redsox985
PA
Home depot has a nice section for hardware. Fastenal is always a good place to look. They have many branches and you can usually dodge shipping costs that way. Especially on small parts that are over priced in terms of shipping.
r97
Massachusetts, USA
my home depot has almost no hardware. lock nuts? nope, spacers? try again, snap rings? what????, but maybe yours is better. your local hardware store should have a few of those bolt sizing charts laying round that you can use.
Bluethunder3320
yeah so today i went to both lowes and home depot to get a vent so i can weld in my basement. first off it was hard to explain to them what we wanted... but finally got it.
i got a 8" in pipe vent.
said 500 cfm
turned out all it does is make a little breeze.
spent 150 bucks total including pipes...... FML
im sooooooooo pissed off.
ill be going back to return it and ill bring the axle with me to match it.
r97
Massachusetts, USA
i'm pretty sure i suggested one of those, but what ever. i agree that would be ideal, on hf it says right in the description "welding fume ventilation", i'm pretty sure any leaf blower that can lift sticks and leaves up 4ft then shred them to bits will be able to handle some fumes (may need to be sealed up a bit but thats no big deal).
Bluethunder3320
yeah you did suggest it.
i thought the home depot thing would be more than good enough but whatever off to HF again..... lol
Bluethunder3320
Yes my parents agreed to buy me the hf blower tomorrow... I already have the plumbing too.
Might be a problem the tubes are an 8" step to 6", than 6" step to 4"...
Bluethunder3320
they would probably get that for me but the thing is my parents want to make the outside vent to look nice and not a duct taped tube.
oh also i welded up the stock exhaust back on the pit bike it is so quiet now.
r97
Massachusetts, USA
i would use like 1ft of 8" metal vent tube, then connect that to the flexible orange tube, then connect orange tube to the blower, put a blower on a stand/ shelf/suspend from ceiling, then but one of these on the blower out put/ outside of house, use your carpentry skills to make one of these, http://www.homedepot.com/h_d1/N-5yc1vZ1xh3/R-100669691/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
or make one of these because it would look cool when you use it, http://www.homedepot.com/h_d1/N-5yc1vZ1xh3/R-100059101/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Bluethunder3320
ya what i was gonna do is make a bracket thing and screw it into the ceiling and then bolt the blower onto it.
i cant believe you found that 8" vent
that is exactly what i need.
when i went to home depot they didnt have sh!t in stock.
r97
Massachusetts, USA
which 8" vent? lol. i was thinking ceiling bracket thing too, but wasn't sure how to describe it, lol.
Bluethunder3320
ya with cut up wood.
first link.
the window is just above ground level so i cant like use link 2 at ground level, lol.
r97
Massachusetts, USA
sounds alot better i should do some hw to (should, hah).
p.s. if the vid doesn't work for you click on the link in the blue border surrounding the vid.
