Hey! This could get interesting...a guy that might actually be able to put an engine back together....
YEAH...I'M TALKING TO YOU FREERUNNER!
Here's a pretty decent checklist for ANYBODY that might need it...
I'm more concerned about all the parts being around when I need them. lol
I know I left the TC bushing with the rest of the TC and now it's missing.
http://smallengineinformation.com/?page_id=512
Above link goes into more detail
REASSEMBLING A FOUR STROKE ENGINE
STEP 1: INSTALL ANY SEALS IN THE CRANKCASE
STEP 2: INSTALL THE CRANKSHAFT
STEP 3: CHECK THE CLEARANCE OF THE CONNECTING ROD BEARING
STEP 4: SET THE PISTON RING END GAP
STEP 5: INSTALL THE PISTON RINGS ON THE PISTON
ASSEMBLE TOGETHER THE PISTON AND CONNECTING ROD
SELECT AND INSTALL EACH RING ON THE PISTON
STEP 6: INSTALL THE PISTON AND CONNECTING ROD ASSEMBLY
STEP 7: INSTALL THE VALVES, VALVE SPRINGS, AND RETAINERS
STEP 8: INSTALL THE VALVE LIFTERS AND THE CAMSHAFT
STEP 9: INSTALL THE OIL PUMP AND THE CRANKCASE COVER
STEP 10: INSTALL THE CYLINDER HEAD
STEP 11: INSTALL THE FLYWHEEL
STEP 12: INSTALL THE IGNITION SYSTEM
STEP 13: CONNECT THE LINKAGES AND INSTALL THE CARBURETOR
STEP 14: INSTALL THE BLOWER HOUSING
STEP 15: INSTALL THE MUFFLER
STEP 16: INSTALL THE FUEL TANK AND CONNECT THE FUEL LINE
STEP 17: INSTALL THE AIR CLEANER
STEP 18: INSTALL THE SPARK PLUG
STEP 19: ADD OIL TO THE ENGINE
STEP 20: INSTALL THE ENGINE ON ITS EQUIPMENT AND START
PARTS CLEANING AND ORGANIZATION
