Thoughts,,,, Well I have heard of doing that. But I always wondered this:
If you are not totally precise... Cant that unbalance things?
I mean it is attached to the crank.
Are these engines balanced?
Would it even matter?
I know on a small block V8 Chevy, they "balance" everything.
Is that just due to the V and opposing multiple cyclinders?
I've also read taping the holes on fan shroud / recoil starter does same thing.
Hmmmmm??
And the exhaust. Only took me 4 hrs to get em both done. Good thing I'm paying myself slave wages or that would have been expensive.
38.48 sq cm bore, 5.5 cm stroke, lets assume original combustion chamber (while head is on with stock gasket) is 28.25cc. (it may be 31cc)
212 + 28.25 = 240.25
240.25 / 28.25 = 8.5 compression ratio
With a 0.036" vs 0.041" (stock) gasket, I'll drop maybe 0.4cc. I think every 0.010" is 0.8cc
With 0.020" longer Rod, I'll drop maybe 2.0cc.
So if I was at 28.25, now I'm at 25.85cc. (probably somewhere near 26-27.5cc)
If it is 25.85cc....
212 + 25.85 = 237.85
237.85 / 25.85 = 9.2 compression ratio
If it is 27.5cc
212 + 27.5 = 239.5
239.5 / 27.5 = 8.7 compression ratio
212 + 25 = 237
237 / 25 = 9.5 compression ratio
Was shooting for around 9:1 compression ratio (guessing somewhere around 8.9, but I'd rather risk being at 9.5, instead of maybe ending up at 8.7.
I think I should of got a thinner gasket... Maybe the 0.027"? I ordered the 0.036" to be safe.
What would you guys do????????
Could maybe get another 0.2 - 0.3 HP from a different gasket I think, but don't want to wait for it.
I'm 0.004" in the hole now. 0.036" gasket gives me 0.040" piston to head clearance. The next thinner MLS gasket (0.027") would still give me 0.031" piston to head clearance.
Hoping the cam, carb, rod, gasket,..... take me from around 9 or 10 HP to 14 or 15 HP, so a 1/4 HP might not be a big deal.
Desertduler
I'm sure I'll loose these lash caps if I don't install the head soon. Some have mentioned loctite on them.
Lash caps are supposed to rotate on the tips of the valve stems promoting longer valve stem tip life and longer lash cap life, putting Loctite between the lash caps and valve stem tips is not a good idea.
Take it from someone who has building engines for over 40 years.
Jrgunn5150
Rudderless
correct, just install them with a little assembly lube on the tips.
Hey! This could get interesting...a guy that might actually be able to put an engine back together....
YEAH...I'M TALKING TO YOU FREERUNNER!
Here's a pretty decent checklist for ANYBODY that might need it...
I'm more concerned about all the parts being around when I need them. lol
I know I left the TC bushing with the rest of the TC and now it's missing.
http://smallengineinformation.com/?page_id=512
Above link goes into more detail
REASSEMBLING A FOUR STROKE ENGINE
STEP 1: INSTALL ANY SEALS IN THE CRANKCASE
STEP 2: INSTALL THE CRANKSHAFT
STEP 3: CHECK THE CLEARANCE OF THE CONNECTING ROD BEARING
STEP 4: SET THE PISTON RING END GAP
STEP 5: INSTALL THE PISTON RINGS ON THE PISTON
ASSEMBLE TOGETHER THE PISTON AND CONNECTING ROD
SELECT AND INSTALL EACH RING ON THE PISTON
STEP 6: INSTALL THE PISTON AND CONNECTING ROD ASSEMBLY
STEP 7: INSTALL THE VALVES, VALVE SPRINGS, AND RETAINERS
STEP 8: INSTALL THE VALVE LIFTERS AND THE CAMSHAFT
STEP 9: INSTALL THE OIL PUMP AND THE CRANKCASE COVER
STEP 10: INSTALL THE CYLINDER HEAD
STEP 11: INSTALL THE FLYWHEEL
STEP 12: INSTALL THE IGNITION SYSTEM
STEP 13: CONNECT THE LINKAGES AND INSTALL THE CARBURETOR
STEP 14: INSTALL THE BLOWER HOUSING
STEP 15: INSTALL THE MUFFLER
STEP 16: INSTALL THE FUEL TANK AND CONNECT THE FUEL LINE
STEP 17: INSTALL THE AIR CLEANER
STEP 18: INSTALL THE SPARK PLUG
STEP 19: ADD OIL TO THE ENGINE
STEP 20: INSTALL THE ENGINE ON ITS EQUIPMENT AND START
PARTS CLEANING AND ORGANIZATION
On a scale of....
Stop what you are doing and put it on now to
Throw it in the trash....
How important is this heat shield???
Jrgunn5150
Rudderless
On a scale of....
I'm pretty sure I threw mine away when I threw the governor away.
---------- Post added at 05:15 PM ---------- Previous post was at 05:14 PM ----------
Fuel pump location ?
I would try to keep it above the level of the carb, unless you are mounting your tank even lower and that's roughly midway.
Too tight! Studs too wide, holes too small. Bumps on the studs make it wider At the base. I may try drilling to 5/16"
Jrgunn5150
Rudderless
That doesn't make any sense, that's your 390 carb adapter right? I would imgaine you'd have to replace the stud's in the head with bolts to the adapter, that should in turn have wider spaced studs on it.
I'm just guessing, but I don't seen how else it would work.
On a scale of....
Where was that? Some of the tin is not a heat sheild but shrouding for the fan to help circulate air for cooling.
