Ok everything got motor oil. Journal, bearings, bolts. 1/4" drive click type inch pound Torque wrench. Started at 60 in lb. worked up to 150 in 20 lb increments. Backed off bolts using regular socket wrench. Started back at 100 in lb. worked up to 150 again in 20 in lb increments.
After setting to 170, the click didn't come easily. The arc video explained this is the norm as this is where the bearing is seating.
Since Poboy is off his game today....
Its KNOW Nothing about not "no nothing about"
Jeez!!!:lolgoku:
Instructions say 0.002 to 0.004" so all good. The crank journal should be 1.188 +/- 0.005". Not 1.180 as I said before. Better measurements were closer to 1.189". If it doesn't meet specs... Just measure again, lol
Edit: +/- 0.0005" I "no" I made another boo boo!
They are either messing up my track or building me a brand new one!
Wrist pin rings will fly!!! Use some needle nose pliers, not a pick. I'm lucky I found the first one.
Normally I'm pretty good at listening for where stuff falls, but I heard it fall into a pile of tools including a spilled container of washers and bolts.
After checking to make sure orientation was correct (arrow on piston top * 2 holes on Rod + hole on Rod cap all line up and point towards the cam shaft). I put stock piston back on new Rod. Stupid wrist pin rings, ugg. First one went in easy. 2nd one, I fought for 5 minutes then it just fell in. Wtf!
My phone thinks Rod is a person.
There's a piston in that there hole.
Didn't put Rod cap on yet but rotated crank to move piston to TDC. Not sitting level yet, but should be close to flush with no pop out. I'll measure again after I torque the bolts back to 170 again.
Desertduler
When you install the wrist pin clips make sure the the open ends face either 6 o'clock or 12 o'clock in relation to the crown of the piston, get used to doing this because believe it or not open end wrist pin clips depending on their outward spring tension can compress at high RPM and come out if the open ends are facing 3 or 9 o'clock when the piston changes directions at T.D.C and B.D.C. That is a reason that they make spirolox wrist pin clips and teflon wrist pin buttons to use in place of open end clips, I am not saying that your engine is going to turn enough RPM for this to happen but as an engine builder I am saying just get used to phasing open end wrist pin clips this way because it has happened and can happen.
---------- Post added at 06:44 AM ---------- Previous post was at 06:19 AM ----------
Another little tip that I might add is when an engine uses bearing shells I always clean the back sides of the bearing shells and their contacting surfaces with acetone in order to remove any oil or grease that gets on them from handling them, any oil or grease left in the back sides of the bearing shells becomes a heat transfer insulator between these surfaces and does not help the heat that is induced transfer away from the bearing shells, it is best that the heat that is in the bearing move outward away from the bearing into the bearing mounting material, connecting rod, block, etc.
Ok I got the piston in the cylinder, the crank in the block, and the connecting rod connected to both the piston and the crank. (I think the open ends are somewhere around 11-1 o'clock on the wrist pin rings, I was trying to keep the open end away from the notch.)
I measured deck height with feeler gauge and straight edge. It seemed to go from 0.0016 to 0.003".
Is 0.0015" or maybe even 0.002" OK or normal for variance in deck height????? I know the piston will rock, right?
Edit: I should probably do this with the side cover on! lol!
Guessing this spring and weight is for compression relief???
In goes the cam....
Can't help but think of Kill Bill when I say Black Mamba
Desertduler
Measure the deck height over the location of the wrist pin, you will be fine with with your deck height calculations. There are many variances that come into play with deck height variations, block deck height to the main bearing center line of the crankshaft, connecting rod bore distances, wrist pin pin bore location in the piston, and actual crankshaft stroke, in a case that the crown of the piston was protruding out of the block to far the crown of the piston can be machined down a little on a lathe but this does not apply to your engine being as you are going to use the head gasket that you plan on using, that spring and weight works to operate the compression release.
Time to lap the valves. If I can ever find the lapping compound. My life has become one constant search for the tool, bolt, nut, lubricant, abrasive.... It's great! I love it!
