Advanced Hemi 212cc Predator Build
Had to reverse engineer the throttle plate. LOL
I am using the cable guard retainer that is designed to be used when the throttle cable comes from the flywheel side (as opposed to the retainer that is designed to be used when the cable comes from the back of the kart).
The cable will come directly from the front of the kart and will be attached to the holder/screw (that holds the exposed wire end) that is designed to be used when the cable comes from the rear.
Using pliers and such I had to bend the lip on the side of throttle plate that is closest to the front of the kart to allow the cable to sit flush and straight in the retainer clamp.
A new return spring (in the opposite direction) works perfectly. Still working on the rest.
Pic soon
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
BLAH BLAH Blah.... How was the Cruise Kaptain?
Your response requires at least 1 Ceazy Broad story!:lolgoku:
First night playing blackjack I may have broken up a marriage. Lol
She was all over me right next to her husband, who was involved some how with the Catholic Church.
She was asking me about physics and I played along. She was eating up anything I said and was like "There's something about Physicists I find fascinating!"
Her husband got angry and left the table. She stayed and flirted and got hammered. She had me betting her chips pretty much.
Table closes and she can't find her key and is bouncing off walls. She wants me to walk her back to her room. I politely agree to help and away go to the 8th deck.
We get to the door, she knocks, her husband answers, I say "Well hello there Father!" and return to my room alone. Lol
---------- Post added at 09:00 PM ---------- Previous post was at 08:56 PM ----------
Any reason I can't or shouldn't keep the original location for the gas tank when using fuel pump.
Poboy kartman
Senior Moments Member
White Settlement Texas
Whew!!!! For a minute there I thought you were gonna say you spent the night with the husband! !!!! Do you have any idea how many Hail Marys that penance is?????
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Going for the Husband is one heck of desperate situation. Talk about "Hail Mary"!! I'll pass.
I was scared it was a swinger couple and and they might try something . Lol
This ladies and gentlemen is how you throttle link a gx390 carb onto a predator 212 using the stock throttle plate in reverse!
This is where I'm like duh I forgot to leave room for the pulse fitting and vac line on the top of the carb adapter below the plate. Frog Snacks!!!!!
Might have to cut shorter or look for some 90 degree fittings.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I took my pulse fitting off the Valve cover.
You are talking for the fule pump right?
Yep. The adapter has a hole for it and also a slug in case I want to put it elsewhere. Figured they knew what they were doing, keeping oil out of the pump and lines. It will work if I cut it down to three tiers instead of 5.... I hope.
Did you use a filter when coming off the valve cover?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
No. I got the info from AGK, also Figured they knew what they were talking about. on their fuel pump install page they showed 2or 3 options for this, and tried all and liked valve cover best and in their trials had no issue with oil. Me neither.
Check out AGK they have alot of parts and info and how to's. Step by step with pics, not just a utube video. I learned alot there. Its cool cause they sell the parts and they actually use them and show you how.
I've read that one too. It's a goodie. lol
I've got till morning to decide. Then hopefully get this thing started. I still need vac and fuel lines. I've got clear tubing I used for air pumps in fish tanks and aquaponics. It might fit the pulse fitting?
---------- Post added at 01:42 AM ---------- Previous post was at 01:41 AM ----------
Tomorrow night is second date with that chica, so hopefully I can finish this early and get my old man nap in before 7. lol
---------- Post added at 01:44 AM ---------- Previous post was at 01:42 AM ----------
"When it comes to the pulse line you have several options. The best option would be to use our carburetor adaptor with the pulse fitting if you plan to use a larger carburetor. The carburetor adaptor provides a clean, strong pulse to run the pump. You do not have to worry about getting oil in pulse line."
"The last option we'll share for getting a pulse to your fuel pump is by installing a pulse fitting into the valve cover. This is the most recent method we have used and to date we have not had a problem with oil getting into the pulse line. When you are using the stock carburetor and a carburetor adaptor is not an option, we think this method is the next best option."
http://www.affordablegokarts.com/fuel-pump-setup.php
Ummmmm????? lol
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Well... I did not remember that part. LOL probably cause I did not want to buy anything. LOL
Oh yeah mine was a briggs and they had Predator adaptors. But they still show using the valve cover and said it would work. even told how to drill and thread it. I have not read that how to in a while.
Ummmmm. Use the "Best option" LOL
I'm going to see if I can get a 90 degree fitting in there with out taking the whole thing off. Eh Hem.... Ultra Grey..... Hmm..
If not, I'll see if it will work if I shorten it 40%.
If not, slug the hole and use the valve cover.
Going to get some oil and gas.
Never been more scared in my life. lol
"Hail Mary, Mother of Grace..."
---------- Post added at 03:16 PM ---------- Previous post was at 03:05 PM ----------
65% Chance it doesn't start, 20% Chance it starts but doesn't run well, 5% chance it runs OK, 5% Chance it runs good, 5% of something much worse - like an explosion in my garage!
Got to bet 3 to win 2, catastrophic failure pays even money!
