Advanced Hemi 212cc Predator Build
Only the first one should take that long. I should probably be able to finish the whole head in an hour. Now that I have a clue, just need a bigger tank/compressor.
Funny, lots of people keep their garbage snow blowers chained up in their locked garages. Weird???
Some Good Stuff to Consider
Compression Ratio vs Octane Requirement
Compression Ratio vs Power
Ignition Timing vs Engine Torque
Compression Ratio vs Ignition Timing/RPM
Optimal Air Fuel Mixture vs Operating Mode
Air Fuel Mixture vs Engine Torque
http://www.daytona-sensors.com/tech_tuning.html
In Summary:
For 93 octane, 10.5 : 1 Compression, 30 degrees BTDC is about the safe limit (depending on engine flow and burn characteristics ).
---------- Post added at 03:09 AM ---------- Previous post was at 02:45 AM ----------
Hope the neighbors don't plan on sleeping in. Just a quick nap for me, then I'm firing up the compressor. I'm going to run it hard. If it breaks, I know what my next purchase is.
I WILL FINISH THE HEAD WORK TODAY!!!!!!!!!!
240 grit Tapered Sanding Rolls / Die Grinder with 3" extension / .25" mandrel / .25" collet
320 grit Tapered Sanding Rolls / Die Grinder with 3" extension / .25" mandrel / .25" collet
320 grit Dremel Finishing Buff / Micro Die Grinder / .125" collet
500 grit wet Silicon Carbide Sand Paper / Hand / 8" Wrist to Finger
Black Emery Rouge / Micro Die Grinder / Felt Polish Wheels 'n Cones / .25" collet
White Rouge / Micro Die Grinder / Felt Polishing Wheels 'n Cones (new for each compound)/ .25" collet
Lap the Valves
Some where between 500 grit and white rouge.
I did 500 by hand and tried the brown and white bar rouge.
IDK?
Finished!
Last pic of the exhaust for at least a bit. Unless the valve won't seal up correctly.
On to the lapping.
I said that was the last pic of the exhaust, so here's a pic of the stock intake for comparison. The exhaust looked similar.
FreeRunner15
R u STILL working on that thing? i like the shinyness. (*u*) lol
anyways for your reference (i guess you wanted to know) the .290 cam doesn't have any P2V interference on a stock head. BUT DON'T RUN LEAN lol. it'll blow off the choke valve. (video proof too)
1. Finish Polishing the exhaust. - Clean Head
2. Check P2V clearance - Clean Head
3. Decide on Gasket Thickness 0.027" or 0.045" (Will use 0.027" if P2V allows)
4. Lapp Valves - Clean Head
5. Install 26lb springs
6. Drain Oil
7. Open and Clean Crank Case
8. Inspect, Clean, Lubricate crank, cam, lifters....
9. Replace Side Cover Gasket with new one, Attach Side Cover, Fill with Oil.
10. Remove Flywheel, Check Flywheel key, Re-Attach Flywheel
11. Set Coil Gap to .030"
12. Seal Head with Head Gasket
13. Attach Carb Adapter with Gaskets
14. Attach studs to Carb Adapter
15. Attach Carb to carb adapter with new gasket
16. Attach Air Filter to Carb
17. Fan Shroud/ Recoil Starter
18. Gas tank
19. Exhaust Pipe- new gasket
20. Throttle Plate
21. Throttle Linkage
21. Set Valve Lash
22. Valve Cover - New Gasket
23. Torque Converter
24. Chain
25. Brakes
26. Jet the Carb
27. Do Wheelies
28. Remove Engine
29. Add Two Engines
30. Do Bigger Wheelies!
31. Check for Valve Seal
32. cc combustion chamber
I will keep the 10.8 lb springs in for the next few tests.
31. Check Valve Seal
32. CC the combustion chamber (see if polishing made a significant difference)
2. Check Piston to Valve Clearance
After that, I can open the crankcase, drain the oil, clean everything, and reassemble. Should be like 3 months and 20 pages.:huh:
Poboy kartman
Senior Moments Member
White Settlement Texas
#33: add 3 jackshafts
#34: add Ford Waterpump
#35: add extra carb
#36: add Nos
#37: get Everclear
#38: drink Everclear
#39: make stupid videos
#........WAIT! MY BAD....(wrong thread)...sorry BOB...carry on....
