Yeah, I’m hoping I can maybe ride around next door but recently they’ve had some stuff stolen so they lock their gate. Maybe(if I get time to) I can post some old videos I have from over there to give you guys an idea on how much room I had… it was nice, I sorta took it for granted, I miss riding there.
Anyways last night I picked up the motor and it looks almost new, much better shape than the Tecumseh. I only had $40 on me but told him I’d pay the rest when I got some cash and he was very understanding and patient(this was like the third time I said I wanted it).
I got the Tecumseh removed and the predator mounted. I haven’t started it yet but the gas has been turned off since he stopped using it. I intended to ride it last night but I got the TAV installed and the sprockets were awfully close(less than 1/8”) to touching. Also my engine shaft bolt is sorta stripped so I have to get another one.
So next I’m going to remove the TAV and cut the ribs off of the TAV mount plate to allow for it to be mounted and clear the sprockets on the farthest bolt hole to the right. I also have to get(probably scavenge around the shop at the CDC) 2 engine mounting bolts because one is stripped and the others threaded section is too short. I’m also going to take the sprocket off and remove the old mount that I put on for support(it’s aluminum and some of the holes are slightly threaded). Then find some low profile bolts for it so that it doesn’t hit the engine mount, maybe take a 1/16” off some socket head cap screws. Also I have to remove the old throttle cable and put the new one on that he gave me because the old one was one for a motorcycle(the nice thick ones) and I don’t want to chop it up.
Also the front left tire that was flat that I patched is still fully inflated. The right rear tire that I put some slime in didn’t hold air. I didn’t put but maybe 1/2-1 cup in, the rim is also bent so that might be the culprit. I’m going to see if the automotive class at the CDC could remove the tire, straighten out the rim, and put the tire back on because the tire isn’t meant for the rim width, someone widened them. I’m sorta looking for 15x5-6 tubes but I don’t seem to have good service when I look.
I’d really like to work on it this week but it probably won’t happen, maybe this weekend.
I almost forgot, I’m gonna have to make another straight pipe for this to. Out of curiosity how long should it be(to avoid bent valves)? Is the length I had before alright, it was probably ~18” in the shape of a “J”?
