After a win at footy I headed over to the shed to work on the go-kart.
making sure the axle will be pretty much straight...
and the pilot holes, very carefully drilled out
Just some (slightly) finer details, adding tubing so the suspension wont slide around
axle is mounted!
a piece of aluminium I will use for the engine mount
cut to size using a waning cutting disk on a grinder with the help of a hacksaw!
engine plate thingo
I have added some neoprene rubber to help absorb a little bit of vibration
oil drops might be a little tricky...
lining things up...
...and i have to remove more links!
finally, after many hours and washers, the chain is tight and ready to go! Yeahh!!
ground clearance may be an issue, which is why I want bigger wheels but they're hard to find
brake drum
brake drum with the brake belt around it.
Remove the Rubber engine pads. They just cause problems. Like chain tension.
Speaking of that. Usually engine plates are slotted so you can slide the engine to adjust chain tension.
Looking good though!
Yes. and yes....Engine plates should be slotted....and rubber pads are a bad idea....HOWEVER... without slots..the "isolation pads" cannot allow the engine to creep.....sooooo...no chain loosening! BUT! It's gonna be a pain adjusting chain tension. Probably the best solution is a plywood base under the engine and a slotted plate....but...whatever...
I was planning on slotting the engine mounting plate but I wnat to take it for a test drive first. And I may remove the rubber if it causes problems...
anyway I began to set up the throttle, no mods or governor removal or anything, I think I will have enough power
I took out the tightening washer cause its annoying
I seriously do not trust these wheels
wait, it needs a spring!
and its all set to go!
Well, I gave up trying to do the throttle as it is, and one of the springs on the governor thing came off, so I started ripping it to bits. But I'm not sure about taking this side off, do I need to mark the screws or not? I'll use the oil for the clutch
