pRoFiT
Can't buy it?, build it!
I skipped a step
Here are the pictures from the brake master mount. Had to put it near the pedal but still close enough for the brake line to reach the discs.
Needed to stick out a little. and i had to move up due to mounts on it.
I could of changed the mount locations but it is aluminum and i don't have anything weld on that.
I think its in a good location under the seat so it doesn't look too bad sticking out the way it does. And if my pedal messes up i can reach down and pull brakes on master cylinder
Took some scrap metal and (messed up a little) shaped it to fit what i needed. Motorcycle brakes are not really designed to mount for go kart use
I angled it a little. should sit level when kart is on ground as tires in back are bigger.
