chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
I Then sanded the entire part smooth with a belt sander
My steering column is one of the 20mm Axles from the Razor Electric karts
The axles have a threaded end, this is an extra axle. The other is on my Krate currently
I found a piece of round stock that fit it nicely.
I then used the center hole left from the hole saw, and a nut to line everything up centered nicely then welded.
Then I popped it off.
This piece will be permanently welded to my actual steering column.
and the Wheel can be bolted on with the three bolts.
My steering column will have the threaded end cut off flush.
Just needs paint!
Custom DIY, not store bought, no fancy lathe, or machine shop, or lazer cut pieces
Just needs paint!
