chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
I have an old Harley 883 tank, put it right up on the engine.
this is going to be goooooood.
Oversize engine? check
lightweight? check
three wheels for less stability? check
bald tires for more donuts? check
oh man this is going to be so sweet!!
So you have changed the engines camshaft design from a split pattern to a single pattern design, has the lobe centers changed at all with this modification? if so what are the lobe centers if I may ask and duration now?Minor update..........
I designed my own camshaft set. Some of the guys on the kz forums across the pond where they are building the cafe bikes with these engines are taking a exhaust side and cutting and milling off the tachometer part of it and installing it in the intake side cause it has more lift. That and i went up from 1 3/8 to 1 1/2 exhaust pipe. So hopefully i can lose some torque and gain some hp.
Whatcha think ? is it gonna work or not ?
And.....................I got me some time to fab the exhaust, coil mount, chain tensioner, and fuel mount so i will get more pics shortly within the week hopefully !
Yes indeed, it is better to be safe than sorry for sure, at any rate you will have enough crazy power to have fun with for sure!I just called web cam they want $500 to regrind my stock camshafts to my specs. So that just might be the safer route so I know they will be a increase. I'm gonna wait til it's running first so I can dyno it first before and after seems how the engine has very low miles and I know it runs.
That is awesome. I like how I'm not the only one building a trike, even though our designs are reversed.
Would love to do a race with you after we're both done.
I have a question Joe, I was wondering how much heat is going to radiate back towards the rider as the trike moves forward from the cylinders and heads? I have never drove anything like your trike I was just curious.
It won't matter....he'll be wearing an Oklahoma firesuit....(shorts, T-Shirt, and backwards baseball cap.....)
