196 cc engine mods
I demand a video showing the 8degree key visual and installation part?(exclude the in-between)
i want/need to see what i will be going through when i set my ignition timing to 31 degrees.
Don't you have your own threads. Ask how to use Youtube in there. Don't Hijack this one.
leesiel
Yardcart 196
Savannah G.A.
Do I still use the black one in conjunction the new adapter? Or do I remove the black one and replace it with the billet one ?
leesiel
Yardcart 196
Savannah G.A.
Did a wristpin search here couldn't find an answer sooooooo. Is the wristpin supposed to be slightly larger than the con rod opening?
I can't seem to get it started in the con rod once it's through the piston; what am I doing wrong?
Had some time to think about things .....don't I need to heat the connecting rod and chill the wristpin to make `em fit? I read that here I think but can't find it now .
leesiel
Yardcart 196
Savannah G.A.
Ok so I put the rod in the oven for a short bit at400° and I put wristpin in the freezer for the same amount of time and no luck getting the piston and rod together. I don't want to grind or sand my rod but don't see how else to do it.
Someone tell me there's a better way.
cavfire
auburn, georgia
The wrist pin should slide in. Before doing anything drastic I'd give ARC a call or whoever you purchased it from. If you have some good calipers I'd take a measurement of the wrist pin to have when you talk to someone.
Poboy kartman
Senior Moments Member
White Settlement Texas
But Bob....your missing the point...(at least the way he told it) .....
That's the difference between "free floating " and "press fit PISTONS. Free floaters just let the pin slide in and have keepers to keep the pin in place. Press fit pistons rely on an interference fit to locate the pin...Never heard of an interference fit between rod and wrist pin?
OK wow I guess I missed a whole post and a half. Sorry just woke up.
---------- Post added at 03:30 PM ---------- Previous post was at 03:23 PM ----------
Parts came in today! Yaaaaayyyy! So this is what 8400 rpm looks like.
Still have not decided on a carb yet ; think I'm gonna go .650 or .670 blueprinted. Opinions anyone?
Can you link this rod? Just to be sure it is the correct rod.
Not too much experience here, but some rods are for different pistons I believe. Not sure if the wrist pin size changes?
leesiel
Yardcart 196
Savannah G.A.
Keeper is only on one side of piston, the other sides diameter keeps the wristpin for going all the way through.
Was freefloating in stock rod, slid right out once I removed the keeper pin.
leesiel
Yardcart 196
Savannah G.A.
I'm getting a micrometer tomorrow and I will measure the wristpin and the connecting rod; if my measurements aren't close I will call OMB warehouse Wednesday and see what they say.
I want my motor back together....:furious2::huh:
P.s. why is there no crying emoji ? How am I supposed to properly express myself in this situation?
leesiel
Yardcart 196
Savannah G.A.
O.d. of the wristpin is 18.19mm and the inside diameter of the con rod is 17.9mm.
Called arc today and gave them my measurements, he measured ( Jody) a few other con rods all of his and mine measured the same it's my wristpin that doesn't work. ( It's larger than a oem wristpin in diameter )
Looks like I'm gonna have to buy a wristpin online as I can't find them locally.
cavfire
auburn, georgia
You'll need a new piston and I'd get new rings as well. There are different thickness rings out there, so why take a chance. Will have to hone the cylinder also.
leesiel
Yardcart 196
Savannah G.A.
Arrrrgggghhh:censored: :censored: :censored:
Well at least there's that emoji !
More parts , more tools , and almost worst of all no time for ridin , worst of all would be the more money I don't have part . ( maybe I should stick up the armored truck that delivers the "po' boy fund" ) :2guns::2guns:
leesiel
Yardcart 196
Savannah G.A.
:mad2:Oh boy my finance department wasn't counting on that .
Back to real work I guess. ( kinda gotta admit it sounds good in theory )
Is G.A.B. Contagious ???????????
