196 cc engine mods
a 60watt Electric "turbo" charger.
i don't know how much energy that is cause it isn't in volts or if it is enough to even do anything. someone does.
P=IV
Watts = Amps * Volts
60 Watts =x* 12 Volts
x = 5 Amps
5 Amps * 12 Volts is 60 Watts! Oh wait. That was given!
Power is product of Voltage and Current.
Don't you come from a long line of electricians?
---------- Post added at 11:44 AM ---------- Previous post was at 11:38 AM ----------
Ford f-350 smog pump?
http://www.partsgeek.com/mnwttby-fo...pp&utm_term=Ford+Secondary+Air+Injection+Pump
Poboy kartman
Senior Moments Member
White Settlement Texas
I think it helps you pee.... I'm just messing around... someone said it that you can adjust the cam timing...but to be honest...I REALLY. don't know...but someone who does will come along and set it straight...but I THINK that's a compression release...to make it easier to start the engine.
leesiel
Yardcart 196
Savannah G.A.
Tomorrow's installation is springs , cam , carb, 8°advance key , New gaskets , New valve cover minus pulse fitting ,an arc billet carb adapter w/pulse fitting and a billet rod.
Wish me luck.
FreeRunner15
Wish me luck.
I demand a video showing the 8degree key visual and installation part?(exclude the in-between)
i want/need to see what i will be going through when i set my ignition timing to 31 degrees.
