196 cc engine mods
leesiel
Yardcart 196
Savannah G.A.
If I wanted only to concern myself with raising my rpms what would my parts list be. I am happy with the way it accelerates already don ,t want to lose to much low end . just trying to get to 7000 -7500 rpms am I being realistic ?:popcorn:
leesiel
Yardcart 196
Savannah G.A.
Yeah I seen the kits was hoping to bypass some parts while still SAFELY raising my rpms . Seems like a Lifan 150 or 200 with trans would be easier and cheaper choice . All i,m looking for is another 10 - 13 mph out of my current setup .6:1 gear 7hp duromax c.c 11" tires Ungoverned she does 32mph ( gps )
---------- Post added at 09:38 PM ---------- Previous post was at 09:31 PM ----------
Your parts list is more of wat i expected and doesn't seem like it would cost 800 $ if shopped for smartly . Cant seem to edit on ps3
---------- Post added at 10:09 PM ---------- Previous post was at 09:39 PM ----------
Would I be better suited to change ratios and use a cvt ?
That's actually very reasonable but, by changing the gear ratio &/or CC to TC should give you what you're looking for...
With 11" tyres, there's no reason you can't run a 5:1 ratio, that alone will give you an extra 6mph; changing to a TC will give you 10% overdrive PLUS you can go to an even lower ratio (let's say, 4.5:1), which should give you the desired 13mph...
13-18 " INCH tires.
That's a really wide scope, which can mean the difference between a 5:1 ratio & a 9:1 ratio; with the current setup, you can, probably, safely go to 15"...
Here's a pic
Not a very good one, I'm afraid...
One thing it does show is that it's a one wheel drive so, fitting a TC may be difficult but, it has been done before...
As it stands, the quickest & cheapest alternative is either swap the tyres for 15's or swap the wheel sprocket...
leesiel
Yardcart 196
Savannah G.A.
The 15 " tires won't be too much on my clutch ? Just the tires alone would get me to 40 mph with no mods except governor removal. (Based on 6:1 ) I ride offroad alot so i could use some ground clearance , (roots and what nots) and take off traction . Would I need to adjust gearing to keep 6:1 or 5:1 with 15" tires .
I,ll upload better pics soon.
I repeat
leesiel
Yardcart 196
Savannah G.A.
Kart wants to run for a while then won't run without choke on ,then it won't run at all. Next time I crank it runs fine for a while then problem starts all over; any ideas? I've cleaned carb ,installed fuel filter,and regapped my plug ; all was good for short while then ....����
leesiel
Yardcart 196
Savannah G.A.
Did the lemon juice boil on my carb .....On initial test run everything seems fine but need to run it for 10-20 min to be sure ; I,ll update tomorrow after I really have a chance to run her hard:2guns:
leesiel
Yardcart 196
Savannah G.A.
OK still having the same problems cept now she won't start after she ran about 10 good minutes. Drawing a blank here. Any suggestions?
More lemony boilin...
Poke and prod, dip and boil....
Rinse(and repeat?) well with the carb cleaner and good to go...
leesiel
Yardcart 196
Savannah G.A.
Carb is clean now and doing fine ( after an hour and a half of lemon boil). Lowered gas tank and installed fuel pump: now she will idle on choke but not accelerate off choke will not idle but will accelerate . Any ideas? Also anyone know where I can get a 10 tooth c c for a #35 chain?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
You cannot get a 10 tooth for # 35 chain. Even a 5/8 shaft is too big for only 10 teeth on a 35 pitch.
Physics.
