$150.00 Pawn Shop find
bshinn
China Grove, NC
Hi guy's noob here from the Charlotte area.
Any idea what I might have on my hands here? Sticker on the SW hub said Cobra 450XL.
5hp Briggs flathead when I brought it home, & according to the S/N it was manuf in 80. 3/4" live axle with 4" band brake, #41 chain.
Poured some gas down the carb, & it started on the 2nd pull. Discovered the shaft was boogered up when I went to replace the clutch, So swapped it for a 212cc Preaditor.
Currently under a restomod for the kids Christmas present, will post some more pix. BTW on the off chance it might be worth something in orig condition, :lolgoku: nothing I did cant be reversed.
bshinn
China Grove, NC
Here are a few of the work in progress:
Nodroz
Belgium (Europe)
Awesome job! The kids will be happy if they get this for their christmas. :D
I love these gokarts, simple, effective and looking awesome!
mr.matt
Houston, Tx
Sweet! Very clean looking from the pics, good find. Did you re-upholster the seat or buy new? Looks good either way!
Have a very close look at the pedals, and see if there's anything stamped on them. At least SOME Clark pedals actually say Clark Mfg on the sides.
soggycrashed
Honolulu
Cool! I have no idea how you will keep your kids from seeing the kart (By the way sexy TL in the background)
I would recommend putting a roll-cage on that. I only flipped once, and that was with a passenger who upset the balance of the kart, but it really can save a life.
What ratio are you going for? 7:1 is probably safe for this sort of thing.
bshinn
China Grove, NC
I only have the kids every other weekend, move it to my storage bldg when they come.
My 44 yo brother, & I (46) both flipped it in the local HS parking lot a few Sundays after I 1st got it running. He stopped himself with his face, I had very minor road rash on the palm of my lft hand.
Both of us got up laughing so hard we almost puked! I have lowered the CG on the cart with different wheels/tires, & it will be ridden mostly of grass. Kids are also getting GOOD Helmets as "stocking stuffers".
Roll cages on yard karts like this are pretty laughable, just something to trap an arm or hand & crush it.
I have the Kart pretty much mocked up, but It's in the storage building....... Ill post some more pix in a few days.
bshinn
China Grove, NC
Here are a few more from shortly after getting it running.
IMO, the reason it flips so easily is because the wheelbase:track ratio is too high (not that you can do anything about it), ideally, it should be around 4:3, yours looks closer to 2:1. Short of redesigning/rebuilding the entire kart, the only thing you can realistically do about it is limit the speed through low gearing
I hope they have biiig stockings :roflol:
:iagree: just ask r_chez...
bshinn
China Grove, NC
On grass/dirt it is fine, will just drift. Get it on asphalt & turn it right.............all bets are off! That 35-40 pounds of motor/fuel mounted high on the left side of the kart makes a pretty big differeince, that is one resaon why the fuel tank is on the floor now.
Wheel/Tire combo went from 4.10/5/11 on 3.5" wide wheels to 4.5/5/10 on 5" wide wheels front & 6.0/5/11.0 on 6.0" wheels on the rear
soggycrashed
Honolulu
Ah. I need mine because: sometimes I ride in rough terrains, like my backyard. 2 acres isn't a lot for riding but it is something!
Also, my dashboard is supported by the rollcage and some other components rely on it like the fog lights and headlights... and the wiring harness!
Edit:
My friend has a friend who was riding with his friend (that's hard to comprehend right there) on a go kart and the thing flipped, he grabbed the top of the roll cage and the 200lb+ kart fell on his arm and cracked the bone.
bshinn
China Grove, NC
"My friend has a friend who was riding with his friend (that's hard to comprehend right there) on a go kart and the thing flipped, he grabbed the top of the roll cage and the 200lb+ kart fell on his arm and cracked the bone."
My point exactally!
