I need help buying stuff!!!!!!!
kartermicah
Washingtonish
i want a go kart motor and controller with an all together cost of 300 $ and i want to go around 30 mph. what should I get and why????
kartermicah
Washingtonish
yeah i know that i was about to buy a 6 hp Tecumseh but i didnt cuz electric has way more torque and its alot more efficient. plus i have an electric pocket bike so i know more about electric. IS ANYONE GONNA HELP ME!
freakboy
the names 'mater
hick town
IMO its much more money to get a electric kart to work as good as a gas kart... its got tourqe but how much are you gona be spending? and if you spend x amount you could probaly get a clone and lightly build it up for cheeper then you can set up electric with a fraction of the weight... and if you wana ride it long just refill and take off again not worrying about rechargin the batterys....
freakboy
the names 'mater
hick town
or you could replace a conecting rod, cam, carb,head,valve train, and flywheel and get something that kicks electronics ***....
kartermicah
Washingtonish
you can talk all you want but i just want some help on an ELECTRIC go kart and if i dont like it than il go gas. BUT FOR NOW i just wanna go electric
freakboy
the names 'mater
hick town
ok have fun hope you got a deep wallet... have u looked into wheel chair motors and regear em?
kartermicah
Washingtonish
well i looked around but they dont really have much of a selection for 48 volt and i dont even know if they are good anyways. i was thinking of going with maybe 72 volts and hook up two 1000 watt engines cuz that would probably do good but for now i think (for the cost lol) im gonna stay with 48 volts and 1000 watts until i get enough money
jr dragster T
Cold place
Look at the price of one deep cell high quality battery. I can assure you on that budget your going scrap steel and a cheap gas engine.
jr dragster T
Cold place
what are you talking about my frame and steering is finished and the tires are on and the brakes are on too. I just need a motor and i am not going gas.......
So you built a rolling kart for less then $300? I have almost $300 in rims and tires let alone on my kart. Sure enough just the steel into most karts is close to that price.
kartermicah
Washingtonish
well if it were motor and controller combined, i would be willing to pay maybe 450 but just the motor i would pay 300 tops. i only want it to go about 25-30 mph.
FBW4
I have 5 electric Go Karts:
72Volt Yerf-Dog SpiderBox Kart, Mars 0709 Motor ($500), AllTrax AXE7234 300Amp Controller ($450) around 28HP tops out over 50mph with a 3.9 – 1 gearing and 20” tires.
4 Honda MiniMotos:
1. 36volt stock Honda MiniMoto, 500Watt 36Volt MY1020 Motor $58, 36Volt 30Amp Controller $20 around 1HP tops out at around 15mph with the stock gearing and tires.
2. 48 volts Honda MiniMoto, 1000Watt 36Volt MY1020 motor $112, 48Volt 50Amp Controller $35 around 3HP. Tops out at around 20MPH with stock gearing and tires.
3. 60Volt Honda MiniMoto, 1000Watt 48Volt MY1020 Motor $122, 60Volt 100Amp Controller $70 around 8HP (in short bursts!). Tops out at around 30MPH? (IN progress)
4. 36Volt Honda MiniMoto, Advanced DC 6.7” 24Volt Motor ($400), AllTrax DCX300 300Amp Controller ($300) around 14HP. Tops out at around 40+MPH with 3.5 – 1 gearing and 6” tires. This Kart is a BEAST and pulls wheelies off the line; I could easily gear this up to 50 or maybe even 60mph.
So in my real world testing:
For around $78 you can go around 15mph (36Volts 30Amps)
For $147 you can go around 20mph (48Volts 50Amps)
And my hope is for around $192 and the right gearing 30mph (60Volts 100Amps)
Of coarse you can also spend $700 and go 40mph or $950 and go 50mph
In most cases you can play with gearing to get a few more MPH just watch motor temps.
