What? I still exist in the stone age! When did we move on?Well if we end up back in the stone age, you guys will be at the top of the food chain.
Are they hiring?The parking lot at work smells like the stoned age..............
Cool man, thanks for that. Ive been waiting until I needed a new chain on something to make this exact comparison. Awesome!Chain stretch is real. Many don’t realize how much.
Below is a comparison.
Old chain on the left, new on the right.
Same 47 links.
Yeah thats the best way i believe. Dry lube cant hurt, it has to be better than nothing.I use no lube.
Nothing to attract grit except gravity.
I use it sometimes. I prefer to use regular oil and clean when needed. I just dont feel like the chain is happy with dry lube. I always feel a few links that are jammed up after the dry stuff.I'm gunna try dry lube. Anyone tried it? Lets hear the good,bad and ugly!
EDIT: Hmmm.. I wonder.. The minibike gets almost exclusively, dry spray. Just yesterday I found a cracked/mostly missing bearing inside the roller. So thats something to consider I guess.
Also, I feel like the dirt and junk that DOES get in there, how well will the dry lube, lube THAT? If its caked in dirt and dust, I think oil would protect the chain a little?
Yeah i'm yanking yer chain.Your pulling our chain.
No way thats the same link count. Show both ends you joker.
How about a lateral bend test. Like this.
Todays topic on Hack's garage, chain lube! Purdy friggen exciting huh?
l see a lot of posts off road stuff here. That is probably the single worst environment for a chain to exist in. Desert moon dust here makes an excellent grindinh compound it has the grit of talcum powder and the abrasiveness pumice.
the problem is what is the best way to mitigate the wear in this nasty environment?
Oil, grease, spary even wax products attract dirt and turn it into grinding paste.
The majority just gets thrown off anyway and makes a bigger mess evertwhere.
Its obvious to me that the grinding powewder sticking to moving parts is causing premarure wear. Switching to dry gonna make it worse? The lack of a more substancal
lube gunna make it worse or mo bedder?
Chain is a wear item, l get that. This chain really takes a beating it should be a #50 chain but that aint happening. Just trying to get a little mo outta dem.
Its not supposed to turn corners like that.
I get the bulk chain at tractor supply.
And yeah the Stoopid thread has morphed to a vast supositary of usless info, kinda like an encyclopedia. Thats it! The encyclopedia of stoopid!Maybe we/you should change the thread title to Hack’s Garage (always liked laboratory though)? I entertain no thoughts that it’s solely based on the Stoopid or will ever return to that.
Naw the Mt. Top Labratory has been around since time began. Through many different managers, but always returning to some form of “motor sport”.
Gawd! enclosed? Sounds good in theory, but what a nightmare (For me)To fab up!What about enclosed chains? Common feature in step-through Honda murdersickles and various European bikes under 150cc. Harley offered it on some bikes in 1984(?) allegedly.
Anyway, the enclosure could either be sealed to permit a constant oil bath for the chain or just prevent dirt and debris from contacting the chain. I think some had an automatic chain oiler akin to a chainsaw. The enclosure may make chain inspection and maintenance a hassle but the chain and sprockets last a looong time. I like the idea and it’s still a thing on modern agricultural motorcycles.
Edit: maintenance is anathema to modern hew-mons.
Agriculture Motorcycles. I don't believe that I have ever heard of such a contraption. In closed chains ? Exactly how many miles a year are we all putting on our karts. Pull the chain off after 5 or so hours of running in the dust, clean with chain cleaner ( the spray can stuff you buy at a motorcycle shop ) put it back on and spray on the chain lube that you bought at the same bike shop. When you're cleaning the chain, if it's got too.much side to side wiggle as demonstrated by WTR, then go back to that same shop and buy a new one. About every two years for myself, but your mileage may vary. Maybe the light bulb just went off. Is " Agriculture Motorcycle" a new sofisticated way of describing what is known as a " dirt bike "?Maybe we/you should change the thread title to Hack’s Garage (always liked laboratory though)? I entertain no thoughts that it’s solely based on the Stoopid or will ever return to that.
