What? I still exist in the stone age! When did we move on?Well if we end up back in the stone age, you guys will be at the top of the food chain.
Are they hiring?The parking lot at work smells like the stoned age..............
Cool man, thanks for that. Ive been waiting until I needed a new chain on something to make this exact comparison. Awesome!Chain stretch is real. Many don’t realize how much.
Below is a comparison.
Old chain on the left, new on the right.
Same 47 links.
Yeah thats the best way i believe. Dry lube cant hurt, it has to be better than nothing.I use no lube.
Nothing to attract grit except gravity.
I use it sometimes. I prefer to use regular oil and clean when needed. I just dont feel like the chain is happy with dry lube. I always feel a few links that are jammed up after the dry stuff.I'm gunna try dry lube. Anyone tried it? Lets hear the good,bad and ugly!
EDIT: Hmmm.. I wonder.. The minibike gets almost exclusively, dry spray. Just yesterday I found a cracked/mostly missing bearing inside the roller. So thats something to consider I guess.
Also, I feel like the dirt and junk that DOES get in there, how well will the dry lube, lube THAT? If its caked in dirt and dust, I think oil would protect the chain a little?
Yeah i'm yanking yer chain.Your pulling our chain.
No way thats the same link count. Show both ends you joker.
How about a lateral bend test. Like this.
Todays topic on Hack's garage, chain lube! Purdy friggen exciting huh?
l see a lot of posts off road stuff here. That is probably the single worst environment for a chain to exist in. Desert moon dust here makes an excellent grindinh compound it has the grit of talcum powder and the abrasiveness pumice.
the problem is what is the best way to mitigate the wear in this nasty environment?
Oil, grease, spary even wax products attract dirt and turn it into grinding paste.
The majority just gets thrown off anyway and makes a bigger mess evertwhere.
Its obvious to me that the grinding powewder sticking to moving parts is causing premarure wear. Switching to dry gonna make it worse? The lack of a more substancal
lube gunna make it worse or mo bedder?
Chain is a wear item, l get that. This chain really takes a beating it should be a #50 chain but that aint happening. Just trying to get a little mo outta dem.
Its not supposed to turn corners like that.
I get the bulk chain at tractor supply.
