Quick Bits
I picked up an electric 2000psi one from Costco a few years ago. I gets the job done for "most" projects. Only thing it doesn't do well with is my driveway cleaner disc thing. Needs a little more psi for that. Do plan on picking up a gas one when one falls into my hands.
Just for S&Gs seen that Protodie was under new ownership finally and seen that they do sell parts in collaboration with KJ Raycing for the VF CrossKart.
Been using Gemini and ChatGPT to see if they can help fix the ST2 plans I have. ChatGPT wants to completely redesign it and maybe use it as a loose template/guideline. Gemini is much more reasonable. That actually can look back into archival forums that were saved in the Wayback Machine/Internet Archive and look at threads of people who built these back in the early to mid 2000s. And learn what people did. Those who built the buggy strictly off the plans had a lot of issues with the frames bending because it used 1 1/2"x1 1/2"x0.065/16ga square tubing, which is way too thin. Front and rear A-arms are like 1" schedule 40 pipe, which is not even remotely structural. Polyurethane bushings with through rods instead of heim joints.
Then to top it off use 1" mild steel keyed shaft, 36" and cut it in three sections, using 2 sets of 1" u-joints. Those ended up breaking apart under acceleration. Badland Buggy tried to make the ST family of buggies a one size fits all to use snowmobile ot motorcycle engines and missed the mark. They should have used one or the other, not set them to to use both, or at least included in the plans to use either one but accommodated it accordingly. On top of that, they really had no solid direction they wanted to go. In the pictures they had of the buggy completed, they used a 2 stroke water cooled snowmobile engine, which back in the early 2000s were still not that common, free air and fan cooled sleds were far more common. And for the motorcycle version, they used like a Honda CB750 inline 4 air cooled, with the engine nearly against the rear firewall, with no oil cooler (these never had one as far as I am aware), so there would be minimal airflow over the heads and cylinders.
Still working in a game plan on what parts to use. It is trying to push me towards using Porsche 930 cv axles, but buy the parts individually vs a whole kit because companies are charging a PREMIUM for off road 930 axles, which makes sense. Main reason is, I am kind of leaning towards using ATV wheels and tires with a common 4x156mm bolt pattern and they do make a 930 stub shaft that will fit that bolt pattern.
Spent probably a solid 2 to 3 hours going back and forth, mostly because once you get to a certain reply amount, your device is using so much processing power that it lags so badly. So I may have to continue with using my computer instead, since it has way more power by comparison. Anyway, spent a lot of time trying to decide on maybe doing Spicer 1310 u-joints with slip yokes or ag PTO shafts since those will have the slip that is required to be used in a double a-arm suspension.
With so many forums gone and a lot of those members fell off, long past, or just don't go online to help share their knowledge anymore, it is harder to do any research into this stuff. While I am not the biggest fan of A.I for a variety of reasons, it is a tool that we can use, as long as we can correct it, which I had to do MANY times to get it on the right track.
One thing to bare in mind, it does use this forum as well as a source of information. Problem is, like many forums, information may not be 100% accurate. I am glad this forum still exists, even if its not as popular as it was when I had joined or even years before I joined.
Long as the information is still good and relevant, its a solid resource still.
Uh oh, you need to give us your man card, Grizz. Electric? By choice? I inherited mine at least. 😁
My closest neighbor had one of those cleaner disc things, a round attachment with nozzles, wheels and maybe some agitator underneath, lying at the curb in its box, so I swiped it. Knew it needed more oompf to make it work though, so I don’t know if it does work.
I want to clean concrete but also wash cars with this newfangled “foam cannon”. Some pressure washers come with a foam cannon……..
I had a gas one, hand me down and the pump went bad. It was roasted. Needed one quick to powerwash my garage siding, gutters and fascias. It works just fine for that and didn't want to spend a lot at at the time. Need a gas for the disc cleaner. It's just like the one you snagged. My dad has a nice gas one that he barely uses, so I'll probably snag that one on day.
My tundra started clunking.
Wow. How did i not notice this before?
Both sides....
Got new struts. Easy peazy. 4 bolts and should be in and out...
Um, why you gotta be like this....
Looked like I was going to have to break a ball joint loose till I tried the swaybar link.
That gave me just enough room to sledge hammer and punch and pry bar the sucker out of there.
Mandatory carnage pic.
And F U flange.
Went back together much easier.
The suns beating down and i took a lesson from FA and his tarp shed...
Now for some lunch and then wrestle the other side.
Happy Saturday 😊
Edit:
Upper a arm had some bad bushings on the driver side. Might as well change them too.
Finished driver side and went back to do the passenger.
Nothing like doing a job twice!
Yep, once I get under a vehicle and go to replace something, you notice everything else and might as well replace it all when you are motivated and got it all apart anyway. Cheers to fixing shyt. :cheers2:
Did the plugs and wires on the truck today. Should have gotten the wires yesterday with the plugs because I had a few break. One actually had the plug wire get stuck on the plug and ripped off when I pulled the boot and heat shield off.
Coated the crap out of the plug wires on the spark plug and coil pack side with dielectric grease.
Coated the crap out of the plug wires on the spark plug…
I used to do that on both ends of the plug wires as a matter of course, plus re-applied antiseize to the plug threads, especially if it’s dissimilar metals
All driveways should have a 30’ permanent awning or open air carport connected to the house or garage (or free standing) otherwise cars just bake unnecessarily. In fact there should be more awnings period, all around the sun side of a house. Yeah I’ll get right on that.
Such a common issue they sell repair/ replacement kits.
Doesn't look like an easy job though.
Too much of a liability that they would just send it off to auction and let someone else deal with it. Oil pressure switch is also bad. Possibly bad o2 or even MAF, no idea. Once I saw the frame rot, I'm like nope we are not digging into this any further.
Atlanta, GA
Ok, subject shift: Why do young people think it's cool for their vehicles to backfire? What's the deal with that?
