One Bad Piglet
Oh, d-d-d-dear!
Required reading (the link at a mimimum), perhaps. Helps you understand Piglet and his virtue.
Piglet is shown to possess great power—a common interpretation of the word Te, which more commonly means Virtue—not only because he is small, but also because he has a great heart or, to use a Taoist term, Tz'u.
Piglet is small but has great power, power to buck you off the seat. Shame about that sissy wheel on the back though, takes the peril out of it.:sifone: Anyways, it seemed fitting.
Hellion, you have too much free time on your hands. :ROFLMAO:
I can't possibly have more free time than you, Mister 10K. Pot and kettle.
:roflol:
Saw this at the store and though it would be helpful. A brillo pad on an arbor.
It took the oxidation off quickly with out taking the original paint down to bare metal. Was just about the right "grit" too. Very little hand sanding needed.
Check this out. I removed a sticker and the OEM color vs the faded color.
Then gave it all some primer.
I have a problem.
I 'just have to' get a bigger carb, exhaust, cam for this thing. I dont know why. Wheelies and spinning tires arent enough I guess.
Just some waiting on parts rambling....
Denny your right. This muffler is a butt burner. I think a center exit with the screw-on can will fit and look nice.
Any experience with those from the peanut gallery?
Then give a mouse a cookie.
If exhaust then why not carb.
Then if carb then head work.
If head work then cam.
If cam then rod...
Does it end?
