- Messages
- 2,825
- Reaction score
- 3,809
High octane gas, low octane gas, booster, no booster. None of this is going to make a big enough difference one way or the other, unless you were measuring power output with very sensitive and sofisticated instruments. If the gas is clean, and relatively fresh, the engine will run just fine. Unless there's something wrong with it, like yours. You are putting way too much emphasis on whatever kind of hop up B S you poured in your tank. Everyday low octane cheap gas ( like what you put in your car to get to work and back ) is all that is required. Don't mix fresh gas with what's in the tank that was put in there by the previous owner, who knows how long ago. Empty the tank, go buy a gallon at the station, and you're ready to go. Pretty darn simple.
