Post your finished projects!!!
Goldwinger
Adams, NY
My rebuild of what I believe is a Klipper Kart.
I sell all of my karts for $100.
Sauer_35
Cypress, TX
I needed something to pass the time with so I picked this up for 100.00. The motor was supposed to run but had sat for 8 months. Well it just need a new carb. Cranked up on the second pull. I did a complete rebuild total cost was just over 500.00. I know I could have saved a lot more if I had just made the seat myself. That cost way too much. Wish I had gone with a darker blue.
G.W
Nyssa Oregon
I want a dingo, instead I'm stuck with the 2 seater I bought for 40 bucks. It'll do the job. I eventually plan to make it full independent suspension and a single seater.
Sauer_35
Cypress, TX
I bought the dingo so the kids friends could come over and ride during the summer and to give me something to work on. I’m trying to sell it for what I’ve got into it. I had the same one when I was a teenager but dang don’t remember it being so small. If I were to keep it for myself I would have to stretch it about 6”. I’ve got a Murray Explorer I ride. The kids have a Fox Voretex. Surprisingly that thing rides like a dream. The kids get mad because mine will do over 50 and theirs are set for 35.
Goldwinger
Adams, NY
Here is my ninth build that I will sell for $100. I know the front wheels are not right but it still turns good enough.
Dylanbeall
utah
Picked this tao tao ATV frame up for 100$ with the intention to swap the engine for a 212 predator. I had to adjust the frame slightly to fit the engine which consisted of cutting some sections and welding it differently. After That put a new straight pipe exhaust, air filter and removed the governor. Originally I had a centrifugal clutch but it had barely any torque so I put a 30 series torque converter instead. I put a new twist throttle in, and a bigger break lever. So far I would estimate I put in about 350$-400$ on this project. In the future I plan to add a wheelie bar, and put the stock gas tank back on instead of the predator one.
Dylanbeall
utah
You should start a thread for your own junk instead of hijacking someone else’s.
That's what the thread said to do, and there's loads of projects on here and you never had a issue, but if it's a problem I can take it down
  • Like
Reactions: G.W
Goldwinger
Adams, NY
I just finished my 10th go kart restoration. This one has some history. The tag tells me it’s a 1958 - 1960 Yazoo Dragster. In its original form it’s worth about $1500. Unfortunately the guy I bought it from cut it and stretched it with another Yazoo. He obviously didn’t know what he had. I had to make a lot of modifications to make it road worthy but it’s finished. I’ll store it for the winter and sell it in the spring for $100.
Goldwinger
Adams, NY
I restored this Carter Kart back in June of 2024 and gave it to my neighbor for her grandkids to use. She just gave it back to me because her grandkids are getting their drivers licenses. I cleaned it up and tuned it up. $100.
