I would try to clean it up with a towel and some carb clean or maybe wd-40. But it probably won’t help it start it’s just good to do since you have it apart. Does it have a low oil sensor? If not That’s all I can help you with sorry. But good luck I hope you can get it runningPulled the head and the valves don’t feel sticky but they are heavily deposited
Thank you. I finally saw a forum that I actually thought I could try to answer so I wanted to help
I’m only 13 years old so I am just trying to help from my experience and I might not be the best help on this site but I have some experience with small engines so hopefully this can help you.Mgerard: those carbon deposits you see are about normal. That's the way any small engine or car engine looks inside, that has any decent amount of hours or mileage on it.
We are on a discussion forum (DIYGK) where you found a thread--> "Tecumseh no start and discouraged" wherein you felt you could contribute by writing a post, message or reply. Just so you know the lingo, FYI and all that.
These are two different engines though. The OP (original poster) has a Tecumseh OHV engine and you showed a photo of your flathead or L head Tecumseh.
and I showed pictures of a Briggs and Stratton 5hp motor not a TecumsehMgerard: those carbon deposits you see are about normal. That's the way any small engine or car engine looks inside, that has any decent amount of hours or mileage on it.
Since you have the head off, now would be a good time to lap the valves and check for leaky valve seats. This way you are 100% sure the valves are not leaking.Pulled the head and the valves don’t feel sticky but they are heavily deposited
I would replace the head gasket.Hey man if it works given the circumstance I’m all for it. I don’t have lapping compound and haven’t really looked over my lap surface yet. I’m thinking maybe debri as well, ima get it cleaned up. Then pull the springs and take a better look. Can I use gasket sealer for the head or do I have to order one?
Oriellys or I gotta order online? Dumb question I’m sure lolI would replace the head gasket.
If it had a fire ring, I would spray both sides with copper gasket spray, a few coats, but I don't see a fire ring on that gasket.
What’s a fire ring?Oriellys or I gotta order online? Dumb question I’m sure lol
A metal ring around the inside edge. Less chance of blowing a gasket, better sealing, handles more heat.What’s a fire ring?
Do not use steel wool on anything inside an engine!! EVER!! The little fine fibers break off and you will not get them all out before it eats the engine!
5 gallon bucket after lapping got it. Didn’t think about it, I could give it a soak in a 5 gallon bucket. Good ideaI DID use steel wool (and other terrible things) on an engine before! You know how I got all the particles, debris and detritus out afterward?
I washed the whole block and related parts thoroughly in a 5 gallon pail filled with warm soapy water.
A guy can also freak out about using valve compound. DON'T DO IT, EVER!!! You will not get all that valve lapping compound (grit) and metal particles out of the engine and you will grind that engine to death when it's running again.See what I did there?
These things can be done without any disastrous after-effects if you're very surgeon-like and ultra fastidious in your work and in your cleanup. I'm not saying a person has to go hog wild and give it a bubble bath either, just saying.
I don't mean to hurt anyone’s feeling by that. I also had a Tecumseh and it didnt look to good (like there was cracks inside the motor) so I got a predator 212
I grew up running the b&s and tec flatheads.I
