Measuring deck height
atlantazombie
Quick post about measuring the piston to deck height on my stock 196cc motor. The piston sits way lower than stock at around 0.04 inches. Any reasons why?
(.035 in. Feeler gauge for context)
BrownStainRacing
Heres a quick mock up. This 1 is actually .004" out.
Make sure the big end of the rod is at the bottom, with the oil slinger. and arrow on piston is pointing down. At least 4 bolts in side cover to hold crank straight.
Allen wrench across the top of deck, measure at 3 o'clock and 9 o'clock with piston at tdc.
atlantazombie
Alright took the cover off and here’s the setup I measured with:
BrownStainRacing
BrownStainRacing
OMB still has the cheapest 14cc head. All your old head parts will fit right in.
You have to unshround the valves jus a lil, about .5 -.75cc is plenty, take the left over casting flash out of the runners, and knock those sharp edges down in the bowl area. Lap the valves to make sure they seal.
Ez Pz. 10.5:1 CR.
212's is gonna play hell trying to keep up with it, 😆 🤣 😂
atlantazombie
Alright I got the parts set up, hopefully this lil motor can turn out to be a beast
I'll use the stock dished piston with the connecting rod, they should both agree on .709 inch wrist pin.
I dont know what the new deck height will be with the longer connecting rod but if it adds +.2 at tdc then im guessing the new height should be .02 in. with a compression ratio of 10.6
Thoughts on buying the head gasket from dover power? The smallest width gasket I could find on OMB was .01 same with GPS.
BrownStainRacing
I suggest
3 side cover gaskets.
Get a shimmed .027" head gasket. You can pull em apart to get .018" and .009". Then you will have extras.
Always get a new piston, rings, wrist pin, clips kit. Jus incase piston to cylinder clearance, and ring ends gaps are off. I start a build with 3 of each, minimum. Mess it up here, and it'll be a......turd.
Crank and cam shims. Look closely at the side of that rod in my pics. It's tore up on the sides. That came outta my 224 with only 3-4 break in hrs on it, before I shimmed the crank and cam. Shims keep everything nice and lined up, less heat, less drag and resistant = a faster revving engine.
Cam choice, stock or performance???
Valve springs gotta match the cam.
Valve spring shims. They set the pressure of the springs. The spring pockets in these heads are all wacked. Not enough pressure will cause valve float, too much pressure will wipe out a cam lobe.
What's the stamp letters on your rockers??? They are different.
And jus think......you jus getting started 😆 🤣 😂 😹 😆 🤣 😂
atlantazombie
Here’s the most current plug on my modified 196cc (NGK BP9ES) .
Currently running a .625in slide in stock style carb with .036 main jet, .020 pilot jet
The fuel/air idle mixture was 2 1/4 turns out from tightened
Let me know what needs to be changed to get it running healthier
BP9ES is a really cold plug isn’t it?
I’m about to try a BP7ES plug with 15psi of boost.
I thought BP6ES was stock and thought it got colder as numbers go higher with NGK
BrownStainRacing
Doesn't look bad.
Maybe drop main down to a .035"
Where's your timing set at???
That color change on the ground strap should be in the curve.
BrownStainRacing
@atlantazombie
Here's best pic I can come up with for that tach wire to plug wire.
My builds with SA bored carbs always has to have a 2000+ rpm idle, to get that snappy throttle response. If not they puff black smoke and sluggish off the line.
They're not rotor tiller motors anymore.
@atlantazombie
I just sent a message to Runleader to verify the CHT sensor works on a plug with 14mm threads. How do you like the temperature sensor / tachometer combo?
BrownStainRacing
Works great.
Tach don't have that delay in it like those cheap square ones do.
It turns on as soon as you start the engine.
Every time you turn the engine off, it will flash (5 times) the MAX rpm the engine turned in that session.
It fits 14mm plugs, that pic there is a 14mm plug.
You gotta turn it off, but I've left it on for days and it's still got the original batteries in it. I have had it for probably a year now.
atlantazombie
@BrownStainRacing I did some testing with the same jetting size and I don’t have numbers for amount of time to get from idle to WOT but I do have some qualitative information.
Based by adjusting the idle/air for highest idle, I get the highest idle rpm at 1.8 - 2 turns out, going from 2k at a little bit past 2 turns out to 2.5k at 1.8 turns before going back down in idle rpm.
Loosening the screw gets the engine sounding almost like it’s chocking out(this is at around 2.5 turns). I checked the plug after running it for not even a minute and it was completely fouled up, carbon buildup.
So unless I’m doing something wrong, it likes being leaner
RPM engagement of ~ 3000
*** One thing I realize is that there is a high possibility that the stock t/c on the go kart is a Chinese off brand***
I attached a video of WOT, turning max rpm of 5800, hopefully works
