please look your karts engine mount over carefully. does It look like it’s been ground out with an angle grinder to fit the bigger 11hp? theres no way your kart has a 5hp mount. That 11hp won’t even bolt up if it does. one of my streakers has a ground out engine plate I can see it’s been ground wider. and the previous owner said he took the 11hp e-start Briggs to a guy to get fixed and the guy told him the engine was junk... So my one streaker did have an 11hp they thought was stock at one point.Thanks folks....awesome guidance.
It sounds like the 11 is the way to go.
Put it with the fat red wire from the battery to the solenoid. Here's an option.So in addition to the large cable from the battery to the solenoid and the 16 gauge wire running from switch lug B to the lug on the solenoid, I would also need a 16 gauge fused wire from the positive battery terminal to where on the solenoid?
Yes.. my mistake.I think that was mentioned by someone earlier that they did come with 11 hp stock and electric start. There is no grinding on the mounting plates or block, so I think it is set up for the 11.please look your karts engine mount over carefully. does It look like it’s been ground out with an angle grinder to fit the bigger 11hp? theres no way your kart has a 5hp mount. That 11hp won’t even bolt up if it does. one of my streakers has a ground out engine plate I can see it’s been ground wider. and the previous owner said he took the 11hp e-start Briggs to a guy to get fixed and the guy told him the engine was junk... So my one streaker did have an 11hp they thought was stock at one point.
The wire in the link I sent? It's just a combination battery and fuse wire. I wanted to show you where the fuse wire went. It goes with the fat positive battery cable.Great....thank you. So positive battery to positive solenoid it is. For the sake of expanding my knowledge a bit, what does that wire do?
That’s true indeed, I know I fit into one of those categories. Spending so much on kids toys, you would know! Two brand new mini bikes, a dream…Awesome piece of history...unmolested, wow good job gramps
Most of the active members are under 15 or over 50 it seems at times, 2nd childhood after spending so much on kids toys![]()
Lol! What was the total cost? Or did you not keep track…And a mortgage![]()
Thanks, Bansil!Awesome piece of history...unmolested, wow good job gramps
Is drill start not good 'nuff? I'm just joking around, wee-hoo! Nice job, I got my "watch" on this thread and I'm waiting for progress. Good luck!So last night I found my way out to my barn (again...) to do some work on the buggy's wiring. As always, I was putzing around the beast looking for missing items and other opportunities to improve, when suddenly I was inspired to check the carb settings (which I had not touched yet).
So I verified the 1.5 turns out on the adjusting screws, choked her up, gave her a sip, and did a crankshaft spin with my cordless drill and socket. Lo and behold....she starts to roar (surprising the hell out of me, frankly) as I "streaked" to get to the throttle control. So I let her run for a couple of minutes ( smiling from ear to ear)...it was a good night!
So, to all my trusted sources of information that have brought me to this milestone, I thank you!
But wait.....the journey now appears to have gone from motor change out to rehab, rewiring just her essentials to reviving the electric start (my new voltage regulator just arrived, by the way) and possibly adding some lighting.....nice work! Stay tuned, we are now about to embark on a whole new adventure....carb and throttle control!
More to come....
All good.....Is drill start not good 'nuff? I'm just joking around, wee-hoo! Nice job, I got my "watch" on this thread and I'm waiting for progress. Good luck!
Well, thank you. It has been my pleasure to work with you and these other great folks....all so generous with your time and knowledge.I've never started an engine with a drill believe-it-or-not! Heard it hurts though... I hope I can help with the throttle, not my specialty but I'll try. I will say you are quite the enjoyable person to "work with". Onward! This Streaker will for certain look better than mine when finished, original paint! If there was a yard kart magazine, this thing would be front and center! That gives me an idea... anyone know sponsors?
