GPS Mega moto's, just pulled the trigger on two!!!
Of course, hope to finish this one tomorrow, I have to buy a socket today...then start on the other one
You’re telling me you don’t have every socket size imaginable? Oh, while you’re at the store, pick up a 1 1/4 inch 1/2 drive socket for me.
Bansil
Painter of gnomes....
I am picking up a 1/4 hex to 3/8 sq and a 3/8 drive 15/16 socket for my impact
I do have a 1 in drive set for working on my bus, they go to 2-1/2 in or similar
Wow...started out as lazy day....we decided to do something at lunch she built a step thing for neighbors dog and planted some flowers......4 hrs later (I was left alone)
4 hours, 3 beverage breaks and was ripping it before the storms....big difference between the two bikes o_Oop
You’re telling me you didn’t go to church? I’m just messing with you, now you got two purdy bikes. Question, why do the have a jackshaft and run it on the right and not just run the chain straight on the left?
Bansil
Corinthians II covers that ;)
And dunno, reckon it's just the kit aspect...you can use everything in these chassis
Eta...except maybe an LS :ROFLMAO:
Forgive the offender! :lolgoku:
the whole chain thing doesn’t make a lot of sense to me, but I’m no engineer…
BrownStainRacing
You doing better then me. I uasally do 3hrs and 4 beverages breaks, back to back, 😆 🤣 😂 😹 😆
BrownStainRacing
You know 1 is a hemi, right???
The hemi has .5 more compression ratio. Don't sound like much, until you have had them on the same bike with the same set up, as you see, there is a difference in only a .5 cr bump.
Bansil
Is the hemi the one with nipple on valve cover? It is definitely stronger
BrownStainRacing
Yes. The hemi has the cast aluminum rectangular valve cover.
If you look at the carb, on valve cover side, it has an adjustable low speed air/fuel. It's a better carb, but not much difference in size.
Also, most of the time the gov spring is in the wrong hole, for utility equipment. You can move it over to pick up another 300-400 rpm before the gov pushes the throttle back. That's on both engines.
