What welder brand(s) are you using?
What brand welder do you have/use for DIY?
  • Total voters
    42
  • Poll closed .
I'd like to get an idea of what everyone on here is using for welding machines. Not the process (Tig, Mig, Stick), but the brand itself. Also comment on what you think of it, how long you've had it, would you recommend it to people, so pretty much a mini review. I'd like to keep this open for a while, as new people come on here and may look to see what others have said and what to look for in a welding machine.
JTSpeedDemon
2019 Build Off Winner!
Texas
I have the Century FC90, a Lincoln brand. I haven’t done a whole lot of welding with it, but I can tell it’s capable of a whole lot! I’ve blown holes in metal despite 90 amps being comparatively low power, and I’ve gotten some very nice beads down even despite my little experience. And man is it a tiny little welder!! I literally have a bun I keep all my welding gear in, welder included! I love being able to fine tune the amperage and wire speed, the adjustments are silky smooth. Actually the whole reason I got a Lincoln brand welder is because my first welding teacher recommended it, and it did not disappoint!
jamyers
Buffalo Gap, TX
Been using the Harbor Freight flux-core for years now, it does a good job on most everything on a go kart - great for the money spent.
redflash
have a harbor freight tig unit....3 years and absolutely no complaints. just the current cost of argon kills me .
Where you located? Last I knew (several years ago unfortunately) it was about $65 for a 6hour or 125 bottle.
redflash
I live in Northern California......About $65.-- for a #80 bottle at 'Airgas' dealer......I could drive an hour to Oakland and get it for $40.00
......not worth the drive.
JTSpeedDemon
Texas
If I had the budget I’d love a Miller wire feed, I’ve only heard good things about them.
We have a Millermatic 211 autoset at work, setup for FCAW for specific recalls. I haven't used it. It is an inverter machine, so its lighter than say a Hobart 190 or 210, which are transformer welders, it's like 38lbs vs 70 or 80lbs respectively. Would like to mention that Hobart is bringing out another welder next week, it's a Hobart Multi-Handler 200, multi-process machine. So mig, tig, stick. Looks like it might be scratch start only tig, I'm not seeing a foot pedal either for it from Northern Tool or Acme Tools. Looks like it's starting price is $1099 or $1199, depending on the store.
JTSpeedDemon
Texas
i have never used a mig welder. though we recently got a tig setup for our stick welder, but we have not set it up yet.
Get one if you can. Yes it's great and all to learn stick, but wow a MiG will do wonders for your beads if you aren't very good with stick. Really convenient too, and easier to store.
Dingocat
Broke
NE Ohio
Have an old lincoln, Idealarc 180 that does ac stick welds. Main purpose of it is for running an arc torch. And also a Hobart handler 140 with flux core. I've been using that for more of my projects and it's worked well. Havent had any issues with it.
Karts of Kaos
the many mowers guy
Wisconsin
thanks JT! i will consider it. for now I will stick with the stick because I am not doing very meany builds. but if i start making more karts I may switch.
JTSpeedDemon
Texas
Yeah mine's a flux core, works a treat, just gotta clean off the flux, but that's fine by me, better than having a shielding gas tank in the garage IMO.
