Ive been looking into your charging mod with the 10 amp flywheel and kohlers 3pole system stuck on my mind due to the 10 amp charging requirements for deep cycle batteries.
Just quickly I found charging requirements as 10% for flooded lead acid and 30% for AGM. I'm guessing 10 amps for a 30AH AGM battery??? Three amps should be good for a 30AH flooded lead acid, from what I read.
This looks to be a 15amp three phase rectifier/regulator
https://www.ebay.com/itm/Voltage-Re...&sd=122481580095&_trksid=p2047675.c100623.m-1
And this looks to be a 15amp single phase rectifier/regulator
https://www.ebay.com/itm/Voltage-Re...122481580095?_trksid=p2385738.m4383.l4275.c10
Here is the 10 amp OEM rectifier used with that flywheel and stator.
https://www.jackssmallengines.com/jacks-parts-lookup/part/kohler/1740308s
I believe you would want to look at Kohler CH270 - 3032 for the 10amp. I was using Kohler CH270-3031 for the 3 amp.
