Rust Bucket!
courts94s
Noob
Fort Sill, Ok
It "Floats" Once the Disc is in between the Caliper shoes it can't fall completely out.
Lame! There's too much play in it. It has a lot of wiggle room when it is in the caliper. I think I will figure out a better way to mount it, so it won't wobble around.
I have the same one on my Krate. It seems you could use the Bolts in the caliper, and bolt to a different mounting bracket.
In that case it is my belief that then you remove the set screw on the Disc (not the Key) and then the Disc floats. I believe 1 of the 2 parts caliper or disc is supposed to float.
I dunno why that is just what I read on here somewhere and more than once.
---------- Post added at 07:03 PM ---------- Previous post was at 06:50 PM ----------
Anyway. Cut off those axle hangers and put them on top.
courts94s
Noob
Fort Sill, Ok
I was knuckle deep in the front end, when I ran out of welding wire!
courts94s
Noob
Fort Sill, Ok
I used a Harbor Freight universal joint to bring the steering column from horizontal to vertical.
---------- Post added at 06:30 PM ---------- Previous post was at 06:26 PM ----------
I just need to weld down the bottom support, and the steering column will be done. Then I have to go back and weld in some small prices to cover the ends of the exposed square tube that makes the steering g column supports. https://vimeo.com/202129419
courts94s
Noob
Fort Sill, Ok
Well.... a key got stuck on the axle, which jammed a wheel on it. I proceeded to hammer, whack, and bang away until the situation got out of control.
Option 1: I can either cut the wheel off, and hope I don't ruin the axle.
Option 2: Cut the axle in half and just punch it out of the wheel.
I've never screwed something up, as bad as I've screwed up this axle! I feel defeated...
fastsr20det
looking goos I was going to say make sure you get a tetanus shot before working on this thing lol its coming along great though
fastsr20det
My bad i spelled good wrong....unlike you. Idk, where im from speil is spell and chick is in the wrong context. Im pretty sure you ment check. So check your self before you come at me with some stupid comment like that.
DUDE!!!! You can't capitalize or punctuate properly. Does i mean you feel so little of yourself that you can't even take the time to hit ONE KEY to elevate yourself to "I"?
I know how to spell spell spell all day long and no...the chick is not in the mail!!!!
I misspelled those words to try and make you see how silly your posts look.
But...if you think you want to have a spilling B wid me, bring it, I garranty I will whoop up on ya!
courts94s
Noob
Fort Sill, Ok
I was curious to see where this would go. I was gonna throw some gas on the fire, but decided to just watch from the sideline.
tinamcjittles
ello m8
Allovau
Did I miss something with fastsr?? Poboy I don't think he gets your sense of humor lolol
By the way Courts love the U-joint, steering at awkward angles is a pain in the neck
"speil chick":roflol:
courts94s
Noob
Fort Sill, Ok
I liked the idea of it too.... the cheap u-joint had too much play, before it would actually grab the wheel and turn. Maybe an 1/16 of a turn, before it would actually turn the wheel. I changed it to a more normal set up.
---------- Post added at 02:28 PM ---------- Previous post was at 02:09 PM ----------
It is nice having the steering wheel and a normal driving angle.
courts94s
Noob
Fort Sill, Ok
Dang hex head broke off inside!
---------- Post added at 03:40 PM ---------- Previous post was at 02:55 PM ----------
The brake is coming together.
Get a couple "Split type" locking Collars for that disc brake with the Broken hex.
The original type never hold anyway.
courts94s
Noob
Fort Sill, Ok
I have some. I had the disk on the axle so I could get the brake caliper mount welded on. It was the head of a ball allen, so I think there will be enough space in there to get a little bit of an allen wrench in. That's what I get for buying the cheap set of ball allens.
I always break those ball end ones too.
Recently I had a really stuck allen screw and I welded a normal allen wrench to it...
It broke! Ooops. at least it was not a set screw though. I ended up heating the thing with a torch and using vise grips to get the allen head bolt out.
Bottom line is Allens Kinda Suck!
Tom Knight
Metal fabricator/welder
Sunny Las Vegas, NV
We may never know! This may be the last wheelbarrow Go Kart I make. While searching for hot rods last night, I discovered something called a Cycle Car (or Cart or Kart). I'm thinking about making one of those next. This is an example of one! It's pretty freaking cool!
They are a gas to drive
