courts94s
Noob
Keep practicing with that welder. You can make a tank. I did. They are expensive $$$ and even an old simple metal one of an old briggs are hard to find.
I used a Piece of 3" tube and welded caps on the end. welded in a 1 1/4" pipe thread nipple for a filler fits a PVC or Steel threaded cap. Also a simple brass barbed fitting can be threaded into a tank for the gas outlet. Cool Stuff give it a try.
My tank is small but can be made any size, It is also Thicker than needed but is easier to weld that way as opposed to sheet metal.
How do you keep the inside from rusting?
