Hero
It was sunny & like 57 degrees here today.
NOT typical for the end of November in NW Ohio.
Ima take advantage...
So, I worked in the floor pan I guess you would call it.
I had some expanded steel left over from another project that should work.
Used the handy dandy cutoff tool to cut it down a bit.
Then measured it out at...
well, the floor is 14" from side to side x 34" from front to back.
So, I marked it & cut notches before bending.
I left ~4" on each side which I bent up @ ~a 45 degree angle.
I left ~6" up front for the foot board & ~18" in the rear for the seat back both bent up @ ~a 45 degree.
Kinda make it look & sound easy but, It took some thought, a lot of riggin'/securing & a BFH (big
hammer)
Test fit it to the frame, Yup, pretty close!
I'll see if I can get it welded up tomorrow.
