Hero
I used the cut off wheel to remove the tabs off of the sides of the scooter & ground off the welds off using a rough wheel on the grinder, before clamping the main frame & the scooters together.
* I finally changed the wheel on the grinder.
Sure got my monies worth out of the old one.
Even had to scrape out debris to fit new wheel on.
After double & triple checkin' everything from (height all (4) corners), levelness & clearance (ground, wheels etc.), I marked the welding points & took it all apart to clean up the welding points.
After using a sanding disc on the grinder, I cleaned everything up & re assembled the main frame & scooters & then tac welded it together.
I doubled checked everything again then welded it up good.
https://www.youtube.com/watch?v=-C3flzyweCg&t=22s&spfreload=10
