Bbqjoe
Banned
Good progress!
I'm beginning to see the crux of the problem here.
Good progress!
Ok So does the engine run with the Home made cam? or what?
Cam timing can be crucial, when doing a regrind. Are you running an advanced Flywheel key?
Good things come to those who wait, right?![]()
Doing so will adjust the cam timing. and increase torque and RPM by volumes.Great... Now he's grinding away the crank...
That's a good one...
I found it's possible to not listen to certain people here, and save a lot of aspirin.[/COLOR]I've found that grinding 1/4" off the cam lobes make it much easier to pull the starting rope.
And for those who don't know it or aren't aware of the fine details about structures, waffles make a much shinier plasma gopher.
I would, but we're way too busy dealing with certain sombrero de culo's.Do you guys use the hand twist chuck drill thing? En espanol, la chingadara?
