Father and son build, need help
45pro
Northern indiana
Ok it's a 15x6 Tire. Axle is not keyed anywhere else except where braking system is. I have access to a welder, a buddy has one. Only thing I think I need a welder for is to attach a cross member so I can weld my engine mounting bracket correct? Oh and probably mounting the gas peddle somehow similar like the brake peddle is
This thing looks like it was a down hill cart...... No provision for a motor, so only a brake was needed.
A good size piece(or 2) of channel would be a good motor plate. have to notch it for the axle, but its not totally un doable...
What are you looking at for a motor? a 212 clone?
You are in Indiana, So BMIKarts.com is pretty Close in Oh. Great prices but the website calculates shipping wrong, and still charges you!
Shop for what you want online, then phone in the order.
Also IMIauctions on ebay has clutches for under 20 bucks. (free Shipping) They are good I have 4. but again
Call Mike directly after finding the ad on Ebay. It just saves him the 8% in ebay fees.303-833-0491.
Nice kart you have a great start, and as you can see tons of helpful guys right here.
I texted him Pictures of a certain member wearing his stickers.
I have not gotten a response yet?
What gives?
That is the correct coupon code right?
Some are us are less helpful. LOL But I try.
45pro
Northern indiana
Ok guys, is this everything I need besides the rear sprocket? Can I get a link to a 2 piece sprocket for a 1" diameter axle? I don't know how many teeth I need or how to mount it to my axle since it's not keyed. Once I get all this ordered I'll figure out the gas peddle, seat, seat belt situation.
---------- Post added at 03:37 PM ---------- Previous post was at 03:35 PM ----------
Hmm...screen shots won't upload for some reason...
---------- Post added at 03:47 PM ---------- Previous post was at 03:37 PM ----------
http://m.ebay.com/itm?itemId=282017373765
http://m.ebay.com/itm?itemId=181745445347
http://m.ebay.com/itm?itemId=182029802065
http://m.ebay.com/itm?itemId=191838656910
http://m.ebay.com/itm?itemId=351826791438
Forget that high dollar cable and bolt kit.
Get a cable from Dicks or a bike shop.
You'll still need a #35 chain, master link, a hub, and a matching #35 72 tooth sprocket. Get the 4 bolts, washers and nylock nuts from Home Depot.
Do yourself a favor and call GoPowersports and tell them what you need. Their prices are reasonable and they don't rip you off on shipping. Mention you are a DIY member and they'll take 10% off.
I think you'll find one stop shopping that'll save you on shipping and prices will be about the same as Fleabay.
45pro
Northern indiana
http://m.ebay.com/itm/Go-KART-SPROC...keyway-WITH-HARDWARE-/130825682445?nav=SEARCH
Is this what I need for a hub? It mentions keyway, how is it going to attach if my axle is not keyed? I'm trying to find and understand everything I need. Then hopefully buy it all at one place when I understand what all I need.
---------- Post added at 06:55 PM ---------- Previous post was at 06:52 PM ----------
http://m.ebay.com/itm/322182828461?...9e45c097422f31d0988c0b&pid=100463&rk=1&rkt=1&
And this would be the chain and master link I need correct?
Just call GoPowersports and tell them what you need....they'll know what you need and send you the correct parts!!!!
Yes...I bought the same chain from Jeremywell.
You need a longer key way on that Axle. You can take that to a machine shop and have them do it. I have one locally that will do it for me free. I just tip the Machine operator.
or
You may need to buy an axle that already has a keyway.
Are you positive there is not a Key way anywhere else on that axle? It may be possible to move the brake to the opposite side (if Keyed) and put your axle sprocket where the brake is now.
45pro
Northern indiana
or
It is not keyed anywhere else. Is it just a solid steel axle that can be grinded to make it keyed?
Yes. But it is a very precise thing. needs to be "machined" not just ground.
45pro
Northern indiana
I assume I can buy the motor there as well? What's the number for these guys? I expect they will be closed till Tuesday though.
Harbor freight will get the motor cheaper.
GoPowerSports.com
10% off with coupon code DIYGOKARTS
866 8 gokart by phone
45pro
Northern indiana
So I found gopowersports and started adding everything to my cart. Free shipping on orders over $200, which looks like I'll be around 250ish. I'm just going to post links to the things I have. Let me know if something is wrong or if I'm missing something.
http://www.gopowersports.com/6-5-hp-212cc-predator-engine-with-clutch-and-chain/
http://www.gopowersports.com/live-axle-hub-4x4/ not sure if this is the right one? Can someone verify?
http://www.gopowersports.com/split-sprockets/
http://www.gopowersports.com/universal-throttle-cable-tc-60/ Will this cable throttle work? Says universal?
