Ok here is what you do. Per BMI:
Use the phone to place the order. The computer automatically does the shipping Wrong.
I complained and they even credited me back some of The shipping
---------- Post added at 11:56 AM ---------- Previous post was at 11:54 AM ----------
"Eric,
A refund has been made back to your credit card for the 7.50. When placing and order online the website cannot take flat rate packages into consideration so they charge the rate of a standard package. You should see a credit to your card in the next 3-5 days.
Thanks,
BMI Karts & Supplies"
I love a good deal.
I overpaid on shipping by a few bucks by not waiting. I paid $14.50 shipping.
For a total of $24.50
I got 20 pedals delivered to my door. 10 Brake, 10 Gas. These fit on 1" square rails.
It was like $9 for 1 set or $25 for 10????
That is a good deal. But why so many?
also While you were at it you should have bought a dozen .99cent red on off switches.
They also have TC covers fr a buck and 3 dollar bow tie steering wheels.
Or for a dollar you can get a 12v DC outlet for your phone charger.
I saw the TC covers. I thought about it. It says mostly used with 40 series. Then I started adding (3) 3/4" Pillow Block bearing for $12 each, (2) 1.25" Axle Bearings for $9 each http://www.bmikarts.com/Axle-Bearing-1-14-bore-_p_508.html
I said 20 pedals are enough! Sets for $20 on eBay!
---------- Post added at 02:56 PM ---------- Previous post was at 02:49 PM ----------
I'm off to try to see if I can find a belt to fit my alt pulley and my axle pulley.
The stock pulley on the alternator is 79.2mm OD and takes 16mm belt (5/8"). With 5/8" belt the Working Diameter of the Axle Pulley is 9.40" or 238.76mm.
This will give me an alternator ratio of 1 : 3.01 from the axle to alternator shaft with 5/8" belt.
With my TC and Drive Gearing....
at 3200 engine rpm 1430 Alternator RPM 7.5Amps
at 5000 engine rpm 2230 Alternator RPM 25Amps
Axle Pulley
1.25" bore, 9.75" OD, Type A V Belt (1/2") or Type B V Belt (5/8")
http://www.surpluscenter.com/Power-T...-1-BK100-H.axd
Alternator
10 SI Single Wire 63Amp 17mm bore 79.2OD Pulley, 16mm V belt
http://www.amazon.com/DB-Electrical-.../dp/B0081S9C16
Need to figure out what length 5/8" Type "B" V-Belt I need once I get the alternator here and installed
Double check ebay on those pedals.
Seller "BMIsteve" (I wonder who that really is) Usually lists everything they sell. So he may have those pedals for cheap too.
But then again most people are not that smart...lol you may make a buck.
On Ebay, an average set of pedals was $15.
These particular ones were were $10 free shipping.
Not trying to re-sell them. Just don't want to have to need to buy pedals again. RESOURCES.
I miss read that. Yeah I guess you are set for life in the pedal arena.
You should buy more stuff and sell it on GABay.
No nevermind that just sounds gay!:surrender:
I will order a 5/8" or 21/32" V-Belt - 36" long.
It will cost around $5 for regular or $10 ribbed (for her pleasure?). Plus $10 shipping. I'm looking around for cheaper Kevlar belts.
I will make a bracket to mount the ALT under the Tubing for the swing arm.
Mocking up the parts, and imagining a 19" x 3/4" JS above the pulley, It seems like the belt will be fine (under the JS and Under the Swing Arm cross member).
18.5" Tires
6:1 gear ratio
44 MPH
4800 RPM engine
800 RPM axle
2400 RPM alternator
35 AMP Out put
3600 RPM
33MPH
15AMPS
Al that GAB on the engine for Fractions of HP per mod, and now you are gonna dump it in the toilet with an alternator.
Oh
and the belt... put the ribbed one on inside out (selfish lover)
Oh
This for the 420 and will only be used when I want.
I'll have 22 HP to play with. The alternator can have a few.
Single wire self exciting Alt wont turn on till I hit 44 MPH, but I will fix that with a switch.
I will make it so I can turn it on and off, and so it only turns on when I want.
If it is a dog, I will tell you.
---------- Post added at 09:07 PM ---------- Previous post was at 08:48 PM ----------
I got this belt. It says 5/8 but I think all BX series v belts are 21/32"
$9.95 Free shipping
http://www.ebay.com/itm/BX33-Belt-BX-33-Cogged-V-Belt-5-8-x-36-Belt-Outside-Diameter-/391028532055
This guy does a really good job. I love his awkwardness. Hard to keep Air vs Fuel straight when covering it all.
Tuning Carb
https://www.youtube.com/watch?v=YxpQjDQzX7g
---------- Post added at 01:12 PM ---------- Previous post was at 12:55 PM ----------
gx390 Carb Tuning on Modified Predator 212cc
Insert new plug.
Set Fuel Screw two turns out.
Warm up engine (Cruise around for 10 minutes).
Toss on stands.
Let engine idle off the Idle Jet. (Low enough RPMs where it is only on the LOW circuit)
I don't want the TC engaged.
Lean out idle mix until engine stumbles (note how many turns).
If you can seat the fuel screw and the engine still runs, the idle jet is too big.
Back out to two turns out again.
Enrichen the idle mix until the engine stumbles again (note how many turns).
If the RPMs increase as you turn the screw more than 3 turns out, the jet is too small.
Looking for the screw setting (between the stumbles) that gives highest RPM, but no hesitation when throttle is blipped and quick return to idle RPM.
If there is a hesitation (looking for crisp, immediate increase in RPM), the idle mix is too lean.
If the RPMs hang, the idle mix is too rich.
OK tried to put a brand new plug in. Wouldn't run. Jiggled some wires. Thought I found a loose one. Tightened it up. Still wont run. Put used, same type, plug back in and it runs fine.
0.026" Idle Jet
1 1/2 turns out fuel screw gives me the best idle and throttle response on stands.
The low jetting seems good (without a plug reading yet).
Turning the fuel screw in (from 2 out) increases RPM.
Continuing to turn it in causes a stumble and will kill it.
Turning out from two turns eventually causes a stumble too.
1 1/2 turns out gives highest RPM, no hesitation, and quick return to idle RPM.
I'll get a video an a pic of the plug. The Plug HAD a fairly dark (blackish) color maybe going up 1 1/2 threads. The tip of the porcelain WAS a nice tan color.
I did some idling and riding around. I'll get a video of it on stands at 1 1/2 turns out. Then I'll pull the plug and show.
---------- Post added at 04:33 PM ---------- Previous post was at 03:59 PM ----------
Here it is. Without a plug reading yet, I think it is close. Will the coloration from before matter when I do look at the plug? I didn't clean it.
https://www.youtube.com/watch?v=mHmKX4cKU2w&feature=youtu.be
