I noticed the cam card says to set lash to 0.003" Hot, I had it set to 0.004" COLD.
I may have found some more RPM's lol
Hmmmm....Who'd a thunk it....actually opening up a valve to the correct height would help performance????
Heck with it...just throw on a couple more carbs and jackshafts, lose the weight of that unnecessary seat ....and you'll be diggin holes and doin burnouts in no time!
It was just for Testing Purposes to see if it ran. Hard to set the lash for a Hot setting when the engine is cold. I'll start at 0.0016" Cold Intake and 0.002" Cold Exhaust and see where it ends up after running a bit when hot.
After checking again, my 0.004" setting was more like 0.007" after a little run time.
The nut and thread on the intake setting seem screwed up. And I can't my the 9mm wrench. Back and forth from vise to engine.. Lots of tiny adjustments and trial and error.
Tomorrow I will check the coil gap. Everyone says 0.030, but last time I couldn't get that. Not enough space. I also heard 0.015". I'll just make sure it is set at 0.030 or as far as it can be.
---------- Post added at 05:05 PM ---------- Previous post was at 04:57 PM ----------
Is 3:5 still the suggested Carb to Jackshaft Ratio?
Before I invested in higher ratio rockers...I add a jack...wait...ummm....I would install the cam and clay the head with the stock rockers to see if there's enough room for the higher lift.
Jrgunn5150
Rudderless
ANYBODY know where to find 1.2 or 1.3:1 Ratio Rockers for the hemi that don't cost 200 bucks?
Not sure what will work with my cam, but just starting to look around a bit.
A 0.275 lift cam with 1.3:1 rockers gives lift of 0.357 ????????????????????????
---------- Post added at 05:36 PM ---------- Previous post was at 05:22 PM ----------
Found these 1.2 steel
http://www.nrracing.com/product-p/hemi-rollrcks.htm
and these 1.2 Aluminum
http://www.nrracing.com/product-p/hemi-rollrcks-bh12.htm
You're doing the math correctly, they add almost no duration, and multiple the lift by the ratio all the way through.
I thought I saw something about Yamaha small engine rockers in another post, but I can't seem to locate it now.
rk970
Coupeville, WA
I glossed through this thread,, What is your compression ratio? From the cam specs it really needs a min of 10:1 (this gives a DCR of 8.4:1) 10.5:1 would be better (small bore size and you can get by with a little higher DCR). If compression ratio is to low for a "cam" you lose power across the whole rpm range...
Also reading plugs for AFR is difficult due to the way current fuel is blended.
Rk
Trust me....if you start increasing lift + have a performance cam with more lift....you definitely run the risk of piston/ valve interference, especially when duration is added to the package! And the ONLY way to know is to clay the head....or blow the motor!
See....the duration can be more of an issue than lift. The piston goes down in the bore several inches....now....if it's at the bottom of the bore....and the valve opens up 2" ....nothing will happen if it closes before the piston gets to 2' from TDC.
But duration means it stays open longer ....therefore, a lift of .020 that poses no problem with a stock timing could theoretically hit the piston if it doesn't close soon enough....(and the clearance is that tight.)
Rk
Can you deduce this from the specs or is compression of 10 written somewhere I didn't see?
It was 8.5:1 with stock Rod 70mm x 55mm stroke and stock gasket. I used +0.020 Rod.
Stock head gasket is like 0.045" I used 0.036".
Piston is .003-.004 in the hole. I have to double check. I can go with 0.027" gasket and still have 0.030" piston to head clearance.
As far as the rockers. I've heard people using Black Mamba Sr with 1.3 to 1 but I would check with clay.
Edit: not sure CCs of original head, but would like it milled
While the hemi head is great for performance, and swirl, combustion ignition , ect....it does provide some additional challenges in figuring static CR and PTV valve clearance.
(Everything is angled!)
I tried to calculate it before but at work now.
---------- Post added at 08:19 PM ---------- Previous post was at 08:12 PM ----------
Right, find the angle of the valve stem to piston top, apply Gee I'm A Tree...
Now I have to lean about static vs dynamic compression. Thanks a lot!! Lol
Jrgunn5150
Rudderless
Static compression is the math, what your piston dish, depth, and combustion chamber add up to.
Dynamic Compression is what you actually have, cams with more overlap will bleed off compression, due to the valves being open during the compression stroke. So you don't get the full stroke :roflol: , but rather some portion of it, actually compressing the mixture.
Piston dish? Sounds good....I'll have that and a side salad with house dressing.....
UMMMMM......NO...this is a HEMI!!!! The piston isn't dished....more like hunchbacked, and the valves are angled into the combustion chamber.....
Desertduler
Yup, exactly, on a added note which is a plus any engine which has canted valves actually breathe better too because as the valves open they are moving away from the cylinder wall and the edge of the combustion chamber therefore unshrouding the valves as they open (which has nothing to do with compression ratios static or dynamic but one of the benefits of canted valve design).
rk970
Coupeville, WA
http://www.wallaceracing.com/dynamic-cr.php
The NO LASH valve timing at .006" lifter rise on the mamba JR is:
intake open 29.275
intake close 57.275
exhaust open 57.275
exhaust close 29.275
Typical SBC, SBF 4" bore you would aim for around 8~8.5:1 DCR. Smaller bore sizes can stand to have a wee bit higher DCR.. (swirl, tumble and quench can vary the numbers also).
DCR is IMO the most over looked spec when building an engine. Its also one of the most important specs and it's dependent on cam choice and fuel type.
Heed the warning about piston to valve clearance, use clay and measure it. Then you can determine how much you can safely mill off the head.
When I jet a carb I start with then main, usually I have about 10 sizes to start with. I start with the biggest estimate (which will be really rich) and then work down until I notice the power to "sag" (not lean enough to kill the engine though). After that point I go back up two sizes. Then I tune the emulsion tube/air correction (mid range/throttle response) then finally pilot jet size. After all that I reconfirm the main jet size.
Ignition timing also effects VE and carb jetting..
Rk
intake open 29.275
intake close 57.275
exhaust open 57.275
Rk
Thanks a ton!!
---------- Post added at 09:11 PM ---------- Previous post was at 09:08 PM ----------
Is that you Peter Parker?
Clark Kent??
Tony Stark????
Thanks again!
Jrgunn5150
Rudderless
That has absolutely zero impact on the difference between static and dynamic compression and how either is calculated.
Also, "Dome" is incorrect, it's "reverse dish"
AND Let's Go Blackhawks!!!!
---------- Post added at 09:33 PM ---------- Previous post was at 09:32 PM ----------
Flat top I think. There are pics somewhere in this thread. When I took the head off.
Jrgunn5150
Rudderless
The height of the piston in, or out of the bore, and volume given up or added by the pistons dish, reverse or otherwise all need ot be figured, here's a calculator I use often in building big engines.
https://www.rbracing-rsr.com/compstaticcalc.html
