Advanced Hemi 212cc Predator Build
This is a duplicate post as I also started a thread on my Port / Polish adventures. I couldn't however leave it out of the engine build thread either.
Using 80 grit cylindrical and tapered abrasive cartridge rolls on a pneumatic die grinder with 3" extension and 4" mandrel. Only had a 3 gal tank air compressor, but it worked - more refill time than work time.
My goal:
- Clean up the casting at the base of the valve guide.
What I actually did was..
- Cleaned up casting at base of valve guide.
- Reshaped front edge of valve guide.
- Reshaped transition from port to bowl on Outside Radius Side (Around the valve guide)
- Smoothed Short-Side Radius (not too much)
- Smoothed valve seat lip (non-combustion chamber side - where seat transitions into bowl)
Mistakes that I'm aware of:lolgoku::
-Probably went too thin on valve guide tip.
Didn't mean to reshape or remove material at all. It just happened as I was trying to get at the base of the valve guide.
-Touched too high on valve seats.
Accidentally and quickly with light pressure. Must have grazed it in a few spots when working the short side radius. Doesn't look bad??? Hopefully lapping will take care of it.
I think it looks better than before, but have no idea if it will perform better.
Now deciding if it's worth trying to do anything to the exhaust side or combustion chamber???
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Removing material from the combustion chamber will decrease compression.
But you knew that.
Don't forget to "index" the spark plug, while you have the head off.
But you knew that.
You think I can get away with this valve guide? Should I take more off top to try to get to thicker material (if it is thicker lower)? Maybe angle the whole guide (keep thick side longer and going lower on thin side to get into thicker material)?
I would just polish chamber but why not let the carbon increase compression for me?:lolgoku:
I have AR3910X spark plug. it has 4 firing points and set distance
ill post better pic later. late for work
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I don't know Jack about what you are doing. I am surprised no one has chimed in with advice and experience. I know there are some guys that know, Send a PM to Desert Dueler...
No wait he is having surgery today, Hurnia :(
I think Russ2251 has done this sort of stuff, and he has been around lately, No wait he hates Predators.
Somebody tell this Guy what he has Done.
Jrgunn5150
Rudderless
The thin as #%@& Valve guide makes me want to get the chrome-molly push rods.
I think your valve guide looks fine, chrome-moly pushrods won't change the valve guide at all. Although a machine shop could bore that one out and press in a bronze one, you'd still have to cut it down so it didn't protrude into the runner.
Here's a better picture of the valve guide.
I want to smooth out the little protrusion where the guide meets the block and at same time make both sides of guide symmetrical. I'm worried that doing any more might cause more harm than good.
Poboy kartman
Senior Moments Member
White Settlement Texas
Put the die grinder down and step away! !!!
Jk...yeah Bob the valve guide is fine...(don't know about the seat)...but don't see why you couldn't lap it back!
Valve guide is fine, looks like you could blend the runner/bowl transition just a little more.
Just to be clear, would that be taking more material out from around the valve guide, going in deeper, at a more gradual angle?
I may not have the nads to go back in! Lol
Plasigauge for connecting rod. 0.002 to 0.006" Red
ARC has a good video on Con Rod install
Installing Connecting rod
This is a very helpful video put out by ARC. I'm sure I spoke with this guy on the phone at least once. I'm not selling ARC, but they have been helpful to me and easy to get on the phone.
https://www.youtube.com/watch?v=owahpOeLYaw
---------- Post added at 03:40 PM ---------- Previous post was at 03:37 PM ----------
KartFab's Video on installing rod
https://www.youtube.com/watch?v=h11vVn5f_3s
---------- Post added at 03:44 PM ---------- Previous post was at 03:40 PM ----------
KartFab's video series is great. I just found it. It's pretty new. Perfect Timing. I think chancer pointed me here, but I did't find it I guess.
Thanks
---------- Post added at 03:45 PM ---------- Previous post was at 03:44 PM ----------
Wrist Pin video - I needed this one too!
https://www.youtube.com/watch?v=vpZcbFXUIQ0
---------- Post added at 04:38 PM ---------- Previous post was at 03:45 PM ----------
Because I'm an idiot, I failed to realize that using a vice for the connecting rod while placing the crankshaft on top requires removing the flywheel.
I don't want to torque the Con Rod bolts inside the block where the crank can rotate.
Going to work soon, so progress stopped at piston removal.
A few minutes to watch about the wrist pin.
It is never a good idea to grind on a valve guide. After some use I have personally seen where the top thin edge of the valve guide breaks off once it gets worn and the valve stem gets a little wobbly. Push rods chromoly or otherwise do not go in the valve guide. :censored: I'm off for the next 3 days now. :wai:
Thanks, that was what i was worried about. I'm aware that the pushrods don't go in the valve guides, but was thinking that flex in the stock ones might cause additional wobble between valve stem and guide. My idea, was that reducing play in push rod might reduce play in valve stem/guide, but I didn't order them. Stock it is
Got the crank out. Measured the journal 1.186" all the way around. The ARC video states it should be 1.180". Maybe my $15 HF electronic caliper is off, or my measuring technique is off. I hope I don't have to thin out the journal.
Time to seat the bearings and check with plastiquage.
Btw, I love my new corded electrical impact wrench..... (And flywheel puller). No more struggles keeping things from spinning. I probably use it more than I should. If I keep doing stuff I no nothing about, soon maybe nothing will spin. EVER AGAIN! lol
---------- Post added at 02:26 PM ---------- Previous post was at 02:12 PM ----------
Only I could loose my connecting rod, guess that's what I get for showing parts to customers at work that probably couldn't care less.
Off to work to get my rod!!!!
Poboy kartman
I've heard some women say you didn't have much of a rod to start with.
