Bighead back. ACDC bar stool racer build.
bighead
Pacific Northwest USA
Some pics. Should have made single long tube. But it is what it is.
Looking good Bighead :thumbsup:
I've always thought a cool feature for a barstool racer would be designing the seat to have a few inches of forward/back adjustment.
Like welding the Stool to the adjustable bucket seat mounts from a car.
That way you could easily adjust your weight bias forward for optimal steering grip, or adjust the seat back further for less-twitchy, strait line cruising at higher speeds.
bighead
Some pics. Will move fast from here out.
bighead
https://youtu.be/IeCRKbkwliw
lower steering block done. Seems to be solid. Going to Change motor mounts to two solid bars and not like now . To manywelds to break pplus lookshack job to me.
Also layed tankup mock style to get ideas to move on. Gonna be sick. I can see it all in my head.
bighead
https://youtu.be/Yep3EuQu1gs
redid lots today. Redid the motor mount to two single rails. Also redid the stool part. Much happier now. tanks in just laying on now. Now i can finish steering and mount tank. I may put some bends in the rear stool bars not sure yet..
Enjoy.
bighead
No weelie bar as of today. Also worried about back heavy. I did not shorten the Fram on this one so fingers crossed the front wheels have enough weight. Gonna test ride it before I weld it all up. If front is light I will make my rear stool down bars in front of the axle. I think going over the back axle has a lot to do with it. My thinking anyway.
bighead
Got steering shaft done. Back bone done. Front of tank mounted done. Still need to mount rear of tank. Big empty spot up front but I do have a wing to fill some of that in. Next I will run some bars from front back to the stool. Side supports on the steering shaft. Nerf bars. The corporate my acdc theme items into the build. Not using the bars. I gonna make drag bike style.
bighead
Gonna get lots done this Friday Saturday.
What do you call these yellow plastic front peace? Looking for black one but cant seem to find the right keyword to search these. Or good site to search for kart plastic?
Thanks.
bighead
https://youtu.be/NdHj0NH-Zk4
got some more done tonight. Moving right alone.
I tried fairing on ebay but nothing came up landuse. I will poke around some more.
