Friday I started the task of removing the engine; I first removed the catcher attachments, cutting deck & rear body section to provide clearance to work; then I set about removing the engine itself, only to realise the pulley attachment needs to be removed from the engine
before the engine can be removed from the frame...
Plan A: Borrow a gear puller. I found my buddy Pete has one but, it's only 4"; gave it a try but, too small to grab the lower pulley;
FAIL!
Plan B: Make a Puller. I had a 6" square x10mm plate sitting around so, I drilled & tapped 5 holes, one M8 in each corner & an M12 in the centre; I also machined a tip for the centre bolt; then I used two lengths of angle above the lower pulley to secure it; all that achieved was bending the top sheave of the pulley;
FAIL!
Plan C: Amongst all my clutter, I found an old sprocket, large enough to make a plate to match the puller plate; some drilling & cutting later, give it a try & all I achieved this time was crushing the
entire top sheave;
FAIL!
Plan D: Ok, this is getting frustrating, let's just drill & tap 3 holes around a 25mm radius & run bolts
through the centre of the pulley; nothing damaged but, still didn't remove the pulleys;
FAIL!
It was at this time that I searched the internet for ideas & they all had the same theme, use a bolt that goes to the base of the bolt hole in the shaft,
not the end of the shaft; I then re-examined the bolt I removed from the shaft; it only has a 3/4" spring washer
AHA! I
do need a longer bolt but, where do I find one on Sunday afternoon?
As I was busy most of Monday, I was unable to source a bolt long enough to do the job so...
Plan E: After measuring the depth of the shaft hole, I used some 3/4" round bar, cut a divot in one end & machined the other end down to 9mm, 60mm long; that then became my centre pin
above the centre bolt of the puller; insert pin, bolt puller on, hit it with the impact gun &
SUCCESS!
