Update:
Sure... I could just get a new set of front axles... weld on a plate... and some skates... but it wouldn't look like the unique attachments that they are.
The idea here was to make an attachment that just bolts on with minimal effort... then again, in the end here... it's still 4 bolts to get them on either way you slice it.
If they were just new axles... it'd be 2 kingpins and two steering rod ends. In my version here though, it's two rod ends and the main wheel nut... slightly easier.
Add the fact that these, can basically be taken off an put on any other ride with relative ease (due to the turnbuckle)... and that's a win I say.
Ok... so...
I mocked up the left side and made one change. That adjustable rod simply would not work where I had it sitting the other day.
Reason? Any rocking motion (e.g. the main hub moving/rolling) would have literally bent the steering arm on the axle.
This way, the movement goes along with the straight edge of the steering resulting in much more strength... but we'll see. The other end, bolted right into the inside of the hub, grade 8 bolts. (10 bucks says this cheap hub toasts itself pretty quick. They seem to be made of pudding)
I'm happy for now and it looks pretty neat.
We're not done yet, and the two pieces are still just wood pattern material... but it'll come together.
If you're curious, I've gone off the deep end here. Sarge's accessories have numbers now. The SA-K01 = Sarge Accessory, Kelly, rendition 01.
And of course, the stencils are hand cut out with a razor blade... just like I do with every one of them. The font, Phantom Stencil.
Next up, cut the patterns out of, oh... steel... and find some tires for the rear rims I have set aside for this whole stupid idea.
But wait... there's more. My boss is tossing a few sets of downhill skis. LOL!
Thanks for a lookin.
