justinlogue5_0
Can't leave it Stock!
Ah, I got ya. Wish I had an easy answer for ya.
All the air filter adapters are sold in the US, and the shipping is more than twice the price of the product, which means the cheaper option would be to make one.
Thanks. The shroud is faded though, so the matched colour wouldn't be very accurate.I painted mine in Massey-Ferguson Red (off the shelf colour); it's not exact (it's a little darker) but it's close...
If you take the shroud to an auto paint shop, they should be able to match the colour exactly...
If you were to upgrade to a torque converter, i would consider a live axle too, that would make the kart more fun.
The axle runs inside that tube..... You just can't see it.....
You still haven't PM'd me. The reason I'm wanting to change to a TC is so that I can keep the 4.8:1 but have a little more take off speed.The axle runs inside that tube..... You just can't see it.....
Matthew, before buying all those goodies, I'd suggest changing the gear ratio to 5.4:1.... That's what I'm currently running, with a modded gx160 and 13" tires. Pretty good set up for the street. Fast on the top, and enough grunt on bottom so it's not slow taking off. I had it at 6:1, but wanted a little more speed. If I change it again, it will be to a 56 or 58 tooth........
Just so you know, it's not really the filter that holds the hp back. It's MOSTLY the filter box itself..... It slows down the intake charge and also restricts how much can go in. I forgot about what we talked about in the pm's. I'll get on it, ASAP......![]()
I'm kind of tired of seeing the stock fuel tank on these engines, so I want to do something a little different.
Does anyone know of a cheap and easy way to mount a remote tank to a go kart? I'm thinking of getting a push mower tank and attaching it to my steering support and then running a pipe to the carb.
