spud guns
Kenny_McCormic
Kartless....
Michigan Troll
what actually happened to it i have ashed but any one on spud files is like don't go their.? lol i was not a spud junkie till recently.
Somebody was hacking it so Joel Surprise(former owner of spudtech, assuming he ever sold it) shut it down and put it in a spudfiles link. I was only there for the BBmgs, built one nice one that I still have( a cloud). I still shoot my old cloud style from time to time when I think to pick up a jar of BBs.
robin
in a house
i made a vortex thay realy eat bbs lol i can use up a 2000 jar in 2 under 2 minis lol its a pain because most of then crack on impact so you cant reuse them
SpyGuy
Hooligan
Tucson, Arizona
However, you must be careful using the Right Guard/ hairspray spud guns due to chemical-thermal removal of body hair....
ricnoah
my bros freands used to have on and it was pvc and you used hairspray and an ignitor
any one know how to make on like that
ed1380
Banned
ATL, GA
what daddy dont know dont hurt him. although hes seen me use it to burn yellow jacket nests under our porch. lol i caught the rug on the porch on fire
robin
in a house
i have solderd copper pipe with a can of deoderent once. made just as good join id i had used my blowtorch
spudkilla224
My spudguns: Far Back To Front:
*Dual Air Chambered Paintball Rifle, with a modded sprinkler valve.
*Basic Combustion with paintball barrel on it
*My Advanced Combustion, Using Metered Propane as fuel,
Advanced Combustion not done yet.
battlebotrock
Escondido
Spud Gun!!!!!!!
I am. I love those spud guns!! the big boom and the smell of fried potato and hair spray!!!! I have one but have not used it for a long time!!!! Here are some instructions for a beginner's spud gun. look up spud gun and you will find tons of cool stuff like the spud machine gun.
Parts
# 2 feet of 2 inch dia. PVC or ABS pressure rated pipe
# 1 foot of 3 inch dia. PVC or ABS pressure rated pipe
# screw off end cap for 3 inch pipe (note: clean out plug may be used)
# slip to threaded 3 inch fitting
# 3 to 2 in reducer
# PVC or ABS cement (note: do NOT mix PVC pipes with ABS pipes or fitting, only use PVC cement on PVC and ABS on ABS)
# BBQ igniter
# 2 drywall screws
# hair spray
# plenty of spuds
Assembly Instructions
1. Cut pipes to correct length's with a hacksaw
2. Glue the barrel and the chamber to the reducer as shown in the diagram. (if PVC is used don't forget to apply primer first.
3. Close off the end of the chamber with the fitting and screw-on end cap or the drain plug cap.
4. Screw the drywall screws through the sides the combustion chamber so there is about a 1/4 to 3/8 inch gap
5. Connect the sparker to the drywall screw and make sure it fires properly, if no spark fires move screws closer and re-test.
6. Bevel the end of the barrel so that the potato will be cut to size when it is loaded. Beveling can be done with a Dremel or if one is not available a file can be used.
7. Let cement dry for about an hour (this time can be used to go buy some spuds!!)
Kaptain Krunch
Pro Junk Collector
vermont
I just made a very small one yesterday. Used all steel construction with a flash circuit from a disposable camera for an ignitor. I used a little 4 or 5 inch long piece of black pipe with an ID of almost 2 inches as the chamber, a small gear from a snowmobile as a reducer to get the end of the pipe down in size then welded that onto a 7 or 8 inch piece of pipe with a 3/4 ID. I havent shot it yet but that flash circuit produces a crazy spark and shocks the hell out of you.
