Kazuma Drifter Modifactions
fanderson
connecticut
Right, progress! :D
I noticed that at the front of the engine, there is something bolted on (see picture). What is it?
IDK what that little box actually does, but its part of the low oil sensor, which shuts off the engine when it doesn't detect any in the crankcase. When you go around a corner in your go kart, the oil sloshes to the side, and the sensor doesn't detect anything, so it shuts the engine off.Theres a sticky on it here http://www.diygokarts.com/vb/showthread.php?t=17624 which should help :thumbsup:.
MatthewD
Senior Member
Northern Ireland (UK)
Yes that`s what I thought it was. When I open the engine up I`m going to remove the low oil sensor and the governor.
Anyhow, I`m now looking for a seat for the Kart. This is going to be doing quite a lot of off roading in fields, really stony lanes etc so I`d like it to be comfortable, cheap (under £40) and available in the UK. BMI Karts do have something of what I`m looking for - http://www.bmikarts.com/Plain-Black-Single-Seat-_p_1241.htm but it isn`t in the UK so shipping price is sky high.
Btw if you have any suggestions, I`d like it to be black vinyl.
MatthewD
Senior Member
Urgent Engine Questions
Cracked open the engine, took side cover off to remove governor. Got the metal arm with the elbow off but can`t seem to get the plastic gear out??
Also, should I remove crankshaft, piston and conrod and clean the engine out as I think there could be a bit of gasket in there.
Someone please reply as I`d like to get the engine going by Saturday
You don't really need to remove the internals to give it a clean. It is not too hard to do so though, so it is up to you.
Post a pic of the plastic gear for some more help
MatthewD
Senior Member
Thanks Landuse. I think I will remove the internals and clean it because it was very poorly looked after, I believe that when I got it (2 yrs ago) it was still on it`s original oil. I think all the gaskets are original too.
Anyway here is the plastic gear:
And here is my custom air filter adaptor:
MatthewD
Senior Member
Nearly finished. Got the plastic gear removed, governor arm hole plugged with a 1/4" bolt and engine all back together. Just needs oil and she`ll run. (BTW I fixed the throttle rod problem). What`s really left to do is,
Tighten up Front Wheels
Tighten up the front axle onto the main frame
Add a kill switch to the steering collum
Add seat
Add oil to motor
Fix clutch
Add clutch
Tighten brakes
Go For A Drive!!!! :D
Step away from the little box you pictured. You need it!that little box with 1 wire coming out of it is the ignition control module, no box = no spark!
I hope I stopped you in time.
:feedtroll:
MatthewD
Senior Member
update!
I now have a rolling chassis
Tried to start the engine yesterday but I noticed there was fuel leaking out of the carb. Gonna take the carb off and have a look
MatthewD
Senior Member
Got some hold-ups :2guns::2guns::2guns::2guns::censored:
First, I was attaching the throttle cable, when the cable snapped
Second, Centrifugal Clutch is knackered. I knew it was done but I thought it might last. Not a bit of it!!! :2guns: :mad: It`s so worn that the shoes don`t engage, the spring is really stretched and everything is just really really worn.
So yeah, got to get a throttle cable and order a clutch. Should be going by next saturday though :eek:
MatthewD
Senior Member
triple posting! no ones replying
Goodies!
Clutch & throttle cable :D
And tomorrow is now today. :D Did you get it done yet?
If you wanted t, you could have bought new internals for your old clutch, but new ones are cheap enough for it not to matter too much.
You must be looking forward to zooming down the road in your kart
MatthewD
Senior Member
Yeah well I`ve nearly got it done. Just need to hook up throttle and finish bolting the engine down. The reason it`s taking so long is because I`m very busy and when it is minus 2 or 3 C it really slows down work.
I can relate.....it's below that here right now....(or was this morning for sure).....but there are poor souls here who are below zero Fahrenheit here!!!!!
