another new guy from NC
danssoslow
Louisville, KY
Here are two pics. The first integrates the angle in the plate; the second is a flat plate mounted to your traditional offset vertical pieces.
Tig
NC
Seriously, they come up with a fancy name for everything here.
Everyone is either a tech, mechanic or and engineer of some sort.
Personally, I think its getting a little outta hand.
dan,
we posted at the same time :)
Very cool, That seems like a very simple design to go by.
Thank you very much, I appreciate the quickness on the info
Nice bumper & the hole on the front is nothing a little fibreglass won't fix; done properly, it will be stronger than original...
As for the header bolt hole, helicoil! IIRC it's 5/16 UNC (18p) which is a common size so, any decent mechanic or auto parts store should have one. As they can be quite pricey, have a look for a cheaper version
Tig
NC
That bumper is a lot nicer than the other one. The other one has a giant crack going up the side, its going to be a little more work but will be worth it in the end. The side panels are also in fair condition. This work will get added to the "to do" list.
I was going to ask about using a helicoil.
Thanks for the info:cheers2:
Tig
NC
Finally the other pics went through
Nice crack.
Both are easy fixes, that I'll tackle some time down the road.
Side panels
Having performed major surgery on fibreglass bumpers in the past, I think it'll be easier to repair the other bumper, you'll end up with a better end result...
Tig
NC
Not much has been going on with the kart lately, to busy at work and around the house.
I have a few questions. The square drive (pawl) had fallen off and several bearings came out. I put the assembly back together and put it back on the motor.
Is there a cover that I can buy to hold that assembly on?
Or
Does anyone know what size the screws are that go in the 4 holes?
Last but not least. What is the best way to start it?
With a drill?
Pull starter?
Thanks guys:cheers2:
It's covered by the pull start assembly but...
Or
it's not an either/or situation, you need both...
Visit your local mower repair shop, they usually hang onto parts like that (both starter assembly & starter clutch)
With a drill?
Pull starter?
The best way is definitely with the pull starter
Tig
NC
Ok, not sure if my mower shop guy is an inexperienced kid or just a db. But, he says he does not know what it is and doesn't have parts for it.
I'm not sure what motor it is to be perfectly honest. Is this a 5 or 6 hp Briggs?
Is there a universal assembly made for it?
Is there a site I could order a new pull start assembly?
Thanks for the help
Seriously? Any moron with a bit of an idea knows it's a B&S...
Check out this thread on how to ID the engine; from there, you'll at least have some idea of direction...
Tig
NC
Yes. That's why I think he was being a dbag, they don't have very good customer service from my understanding. I'm new to the neighborhood.
Thank you for the link. I'll be checking it out tomorrow.
Thanks again:cheers2:
Tig
NC
Found some tubing for the exhaust.
The exhaust on it now has 1" ID tubing, this is 1" OD tubing. I don't think it'll be a problem. I also have one U bend of 1-1/8" tubing I could step it up to towards the end of the system.
